Question about Canon BubbleJet i560 InkJet Printer
Printer suddenly dead
My canon i560 on my mac mini os x tiger suddenly one fine morning had no power. All efforts--unplugging and re-plugging, using a different outlet, using a different system in a different room--failed to turn its power on! Canon tech support--on hearing the problem, and what fixes I had tried--glibly responded by saying the power unit is dead, and I'll have to take it in to their service center. But how and why did the power unit die--when the rest of my system didn't--threy're plugged in to the same surge protecter? This is crap--this the third canon to die on me in the space of a little over a year! I should add I use the printer for light occasional, mainly, text printing. My confidence in Canon is all but gone (have they now abandoned reliability--a dark suspicion!). Pity, because I was a sworn Canon fan. If anyone has any solutions--I'd be grateful.
  • 624 Answers
It's possible the power supply died, however, there is a 3amp fuse on the slide in power unit that could have blown. I would check it before taking it to the recycling pile. If you mess with it be careful around capacitors, they'll hold a charge even if not connect to power for several days.
Posted on Nov 26, 2006
I have install osx 10.4.11 on G5 intel, internal harddrive.Then i install the harddrive to mac mini PPC 1.42 GHZ . Now it will not boot. Only gray display. If i take harddrive out i will boot. What's the...
Did you use a system specific install of Tiger (OS X 10.4)? If so, you need to use the retail version of the OS so it will work across the board with all Macs.
Mar 05, 2010 | Apple Mac mini
Our i560 suddenly will no longer turn on
Sure it is, try removing the inks and then the printhead. If it will power up with them out, you need a new printhead. Don't put the old one back in as you could fry the logic pcb. The printhead part number is stamped on the side.
Nov 03, 2009 | Canon BubbleJet i560 InkJet Printer
HP 1022 Printer, OS X 4, printer jam
Unplug it for a minute or so. Make sure all the paper is out. Turn it back on. Macs usually have their own drivers. Did it come with a disk. Please rate me
Jun 18, 2009 | HP LaserJet 1022 Printer
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Feb 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My friend is trying to hook up his Cannon i560 printer to Apple -macintosh comp.Where do I find instalation feeds live?
You can download the printer drivers by visiting the following link ..
http://printers.free-driver-download.com/2665/Canon-i560-Printer-Driver-v4.50-Mac-OS-8-9-&-Mac-OS-X.html
Just scroll down and enter the validate code thats given in the window ... and then click on Download button and the download will start ...
Jan 23, 2009 | Canon BubbleJet i560 InkJet Printer
My Mac os X v 10.5.5 suddenly won't print to my Canon MP600. I keep getting error number 306. I have restarted both the printer and Mac. I have restarted my wireless airport. Nothing works. Any ideas?
My MP600 came up error 306 for no reason. I unplugged everything and plugged it back in again (I found a clump of dust at the USB port on the hub, which could have been involved) - the printer worked again no problem.
Jan 09, 2009 | Office Equipment & Supplies
Scanner suddenly disappeared from the Applications folders.
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Oct 14, 2008 | Canon MP970 Photo All-In-One InkJet...
Canon i560 print driver for Mac OS X 10.5 (leopead)
Ruth...unfortunately you must wait on Canon to get a print driver that works.
Background: In the process of creating and publishing new operating systems Apple contacts all of the peripheral manufacturers that they have to support and gives them the interface criteria for their new operating system. In this list is printers. When the operating system is published it does not include all printers because many times the printer manufacturers don't have time to react.
One of the criteria is how good is the information that Apple gave them for the interface. Printer drivers are time-related and often are tricky to write. This sounds like the version that you have (4.83) is not a good version or may be interacting with other software combinations that only you have that weren't tested. I wouldn't be suprised if they came out with 4.84 this week.
Your best bet is to contact Canon directly with your problem and keep on them until they have it solved. Mention that your only option at this point is to buy someone else's (not Canon) printer. Every new version of a print driver is some solution to a problem that they have had in the past or a new compatibility with new operating system. Remember that Canon has limited resources and money (incentive) to fix your problem and may not be as responsive as you would like. Also, Apple is still the minority player in the operating system market (less incentive).
My solution: continue to contact Canon until you get an a fix.
- cost...your time and effort. Time to fix...???
My second solution: buy another printer (not a Canon). Make sure it is in the list that Apple (specifically Mac OS X 10.5) says they have drivers that they have tested.
- cost...$150US maybe. Time to fix...immediate.
Jul 20, 2008 | Computers & Internet
Canon PIXMA MPA830 power loss
I had a similar problem after a power surge. But when I left it unplugged for 10 minutes and then plugged it back in it powered up just fine.
May 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Communication error
Marky12, if the printer works fine on the vista system then you can eliminate a hardware fault. sounds like a driver or install issue. remove the printer completely from the mac (uninstall software, drivers and unplug) then go to epson.com, choose your countrey and head to the support and downloads section. Get the latest drivers for mac/tiger and reinstall the printer (make sure you have restarted the mac in between uninstall and reinstall) and most important !!! dont plug in the usb cord until the driver install tells you to
Good luck
Feb 28, 2008 | Office Equipment & Supplies
Canon BubbleJet i560 InkJet Printer Logo
223 people viewed this question
old marine
old marine
