Question about Garmin GPS
Garmin Nuvi 5000 01101697 Unit takes up to 20 min. to recieve signal. Looses signal frequently even when standing still in a open area.
5 Suggested Answers
Sudbury
  • 18 Answers
SOURCE: need instructions how to use garmin nuvi 5000
You can obtain the manual for your nuvi 5000 at Garmin.com
If you would like to learn some tips and tricks relating to your gps you may want to check out Gary Hayman's web site. Just do a search for his name. The advice he gives is not specific to the nuvi 5000 but in most cases it is applicable.
Posted on Aug 02, 2009
Sudbury
  • 18 Answers
SOURCE: Garnub Nuvi 500 power source
I have checked around but can't find anything smaller than 12 volt booster pack, the type used for boosting car batteries. They have a cigarette lighter outlet. They are quite heavy to carry around after a while but they can come in handy depending on the circumstances.
Posted on Aug 04, 2009
SQUIRESXX
  • 486 Answers
SOURCE: Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Posted on Dec 12, 2009
sharcnet
  • 2130 Answers
SOURCE: Loses satellite reception frequently, even standing still!
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Jun 09, 2010
Im not getting any signal on my garmin nuvi 255w
If your garmin nuvi 255w in not getting any signal try to reset the unit by holding the power off/on button for about 15 seconds, that way it will restart the unit and it will start to work properly, but if it does not still work, then you need to disconnect the gps device and take it out of the car to an area where the gps will directly face the sky. That way it will receive signal. Or you can connect an external antenna to it.
That should do the job.
Jan 02, 2011 | Garmin nuvi 255W GPS Receiver
Dec 12, 2009 | Garmin nuvi 1300 Car GPS Receiver
Just purchased a garmin nuvi 205W in Florida. It
This device should find a signal nearly anywhere it is used. The further away from the earth's equator it is used will increase signal lock or "fix" time though. You should be able to get a fix by bringing the unit into an open space (few / low trees, buildings, etc.) and leave on for up to 20 minutes. The GPS should provide an accurate location in this amount of time and should be able to fix in a moment or so from that point on.
If you have troubles still, contact Garmin Support below:
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
I've got a RAC Sat Nav,it takes cver 20 mins to get signal,help
make sure the batteryb is fully charged by AC charger not car charger which is only a mani\tenance charge
Oct 17, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin Nuvi 205 Problems aquiring stellite
usually gps are automatically sensing the signal, with clear view without and sometime even with minimal obstruction like trees windows etc. there is no other way your gps could not acquire signal unles it is having a problem .
all gps thesedays have 10-20 meter accuracy, it is only a receiver, this model particularly have the highest signal.
in other words i suggest you reset your unit from the bottom and see if there is any improvement, replace the unit
cheers
Sep 04, 2008 | Garmin Nuvi 660 GPS Receiver
Traffic reciever not working with Nuvi 650
I have the Nuvi 650 (for about a year now) and just bought the GTM-20 traffic receiver. This receiver came with the "free lifetime" traffic service. (Keep in mind that at first use, the receiver is "mated" to the Nuvi for "life". You can't move it to another GPS).
In any case, the GTM-20 manual says you only need to plug the two together and the two units will establish their connection automatically.
Mine didn't work.
I called Garmin and after a LOOONG hold time, finally got through to a tech rep. She advised that I connect my 650 to my PC and login to Garmin to check for upgrades. She was right. When Garmin offered this "free service for life", they had to issue a new software update so the Nuvi would accept it. She also advised I check the offered "optional" upgrades as well, and look for any that offered "traffic" in the title. There was one of those upgrades, also. (almost everything else was optional "voices" downloads).
I downloaded both the primary software update and the optional traffic update to the 650. It installed them automatically. She also advised "just to be sure" to do a hard reset on the 650. That involves turning the unit off. Then, while pressing a finger in the lower right corner of the screen, turn the unit back on. The unit will ask if you really want to risk losing personal data.. Say "yes", and the unit will do a clean reboot with the upgrades.
Reconnect the receiver and the 650. It may take awhile for the units to acquire the satellites, traffic signals, and set the internal key, but it did work. You may not see the "traffic icon" at the first map screen. If you go to the tools or setup screen, you should see the traffic icon at the lower right of the screen. Press that, and if you are in a coverage area, it will show traffic in the area.
If you have the first version of the GTM-20, you will have a set of LEDs on the power plug that show power and traffic signal info. If you have the new version of the GTM-20, there are no lights on the plug.
A couple of side notes. If you have a lot of "favorites" saved in your 650, you may lose those on the hard reset. To avoid that, put your 650 on the PC, go to your file explorer, and go to the "Nuvi" drive. Click on that, and find the the folder and file called "gpx". Copy that to a folder or desktop on your PC. After you do the nuvi reboot, reconnect the PC and copy the file back into the folder on the 650. That will restore your favorites.
Also, make sure you are in a covered area. If you are not, it won't find the signal and will not show you any traffic icon.
The first time after the upgrade and reboot, the Garmin rep said it could take anything from several minutes up to nearly an hour for it to establish the link (mine was about 10 minutes). After that, it will come right on.
A lot of information here, but the first thing is to get the latest software upgrade for the 650. I had upgraded mine about 4 months ago, and it was already two versions out of date. The newer version had the fix for traffic. I would start there.
Apr 17, 2008 | Garmin GPS
Dropped signal after 10 min opertation
This sounds like a thermal issue. Maybe the lcd is overdriven and getting hot. To find out if this is the case, blow cold air on the receiver while it is running. If it stays connected longer than normal under these chilly conditions, then chances are that some component is overheating and shutting off. It will be most likely a transistor on the signal receiving portion of the board. In that case, I am sure that you will need to send it in to Garmin for repair. Good Luck!
Jan 30, 2008 | Garmin Nuvi 660 GPS Receiver
Loss of signal after about 10 minn of time
If it happens around the same suburb the sattelite can't get to that area.
Or it is programmed for another location meaning : it wont display most of the places near you.
Or if its old it wasn't programmed with all the streets as new streets do get built alot.
Also this GPS is a pretty bad one as I am already dealing with 5 others They are all 660s and are the only GPS with problems.
Hope this helps - Josh
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
