Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher leaving film
There is a whitish film left on dishes/glasses/silverware after wash cycle is finished. Even if I use the extra rinse cycle, I still have to wipe the film off.
  • efrey25 Nov 16, 2008
    I have used rinse aid, changed from the dw detergent I was using, and even "cleaned" out the dw with vinegar. There must be something out there than can help. I have blue glass dishes and glasses and you cannot imagine what a mess they are. I either have to wash them by hand again . . or wipe everything hard with a dish towel.
    President:
  • 1,462 Answers
White film is nearly always due to no rinse aid. it is laborious to do but check that rinse aid is being released. take outer door off and operate dispensor by hand to check release. also check the setting on the dispensor.
pue a multimeter on the solenoid and check that it is energised during the cycle
tresilla
Posted on Nov 17, 2008
    President:
  • 1,462 Answers
Are you using rinse aid?
Posted on Nov 16, 2008
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
Tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 | Dishwashers
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
Daniel
Jan 07, 2011 | Kenmore Dishwashers
Dishwasher seems to run for a very long time on normal cycle. It leaves a whitish residue on dishes and the glasses appear cloudy. I do use a rinse agent.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 21, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Soap residue on glasses & silverware
Try changing the type and brand of detergent as some are better than others. Could the water softener need service? If you wash/rinse any dishes in the sink, do they have the same problem? Good luck!
Apr 06, 2010 | Dishwashers
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Film on Dishes
We had this problem too. We switched to the Electrosol tabs (with the red dot in the middle) for soap, and it seems to have fixed the problem. Make sure you have the rinse aid in there too. Good luck!
Dec 30, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Are you using Jet Dri or another type of rinse agent? If not, that will become your main issue. These machines HAVE to have it, or they wont remove that film. Also, have you changed washing agent (soap) etc. You may be using a little to much. Other issues that can cause this are: bad drain or main pump unit, clogged drain hose, etc. Let me know if you need any other help or information.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
356 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
