Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
My sony KP51WS510 Too blue or red, double exposure
Sometimes, my tv will have a double exposure and the color is overly defined, such as the blue and red will be very blue or very red. I don't know how else to explain it.
  • michele898 Nov 18, 2008
    double color red and blue sp[lit image i can figure out how to line up the colors.
  • scottro Dec 04, 2008
    my tv has a double exposure and the color is overly defined, such as the blue and red will be very blue or very red.
    New Friend:
  • 99 Answers
This type of fault is harder to locate since the I cannot see the picture my self.
It could be a convergence problem or G2 problem. Either way U should take to a service center.
I don't think this is just a do it ur self kind of fault
Sorry. I can't be of any more help
Rifaa
Posted on Nov 20, 2008
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
I have big screen (53") Soni TV that I had bought
Hi this is a common issue on this sets I also have the aame problem with my sony ,whats your model number?
Apr 18, 2011 | Sony Televison & Video
Sony KP51WS510 in Rear Projection HDTV Television has red shadow
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Sony KP-51WS510 51" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
I have sony model KP51WS510 with a red and green shadow also the color is off
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Color on tv not maching
Sounds like convergence issue....Can you describe " colors
go nuts"..........If red green or blue separate, replace STK392 IC's
located on large heat sinks.........T.
Oct 29, 2007 | Sony KP-51WS510 51" Rear Projection...
Problem with picture - "double exposure"
Your set has what is know as convergence problem and is a popular problem in the rear projection sets,the only way to correct the problem is by replacing the amplifiers in charge of aligning all 3 colors,your set might only use two amps for all 3 colors,The IC's(amps) are both the same number and they are mounted in heatsinks because they get hot,they have a number in the front that looks like this STK--- ---,they run about 25.00 each and replacing them can be difficult because they need to be unsoldered and removed without damage to the main circuit board ,then the new ones need to be soldered in,sometimes the new ones need to be aligned from the service menu so all three colors line up.If you are familiar with tv service you have now a place to direct your attention but if you are not too familiar be safe and call for assistance from a servicer.Let us know if you need more information.
Nov 07, 2006 | Mitsubishi VS-45609 TV
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
