Question about T-Mobile Sidekick ID Cellular Phone
The screen light is not working
It just never goes on when i reset it pop out the battery still nothing
  • 625 Answers
Bad news, the backlight is probably blown on you sidekick ID. You can replace it fairly easily if you can find a replacement.
Take a look here to see if any are available on ebay.
Sidekick ID LCD Screens for Sale
and here is a guide for replacing it. The guide is for a sidekick 3 but the procedure is exactly the same.
Posted on Nov 20, 2008
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
Sylvania Netbook 7
sounds like the bios battery is dead , it looks like a watch battery and may be soldered to the motherboard. I would trash it and get something newer. any new android phone or tablet would be better.I would suggest the 7 inch fire tablet for $50
Apr 21, 2017 | Sylvania G-Netbook
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
When I press the "On" switch nothing happens.
well how did he go around resetting the bios, did he open the device and remove the battery becuase if he did he most likely fried ur system. since the devices have power but nothing responds. however this is not applicable if the screen shows bios setttings
May 07, 2009 | Toshiba Satellite 1805-S274 Notebook
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 23, 2009 | Philips SA3025/37 Flash MP3 Player
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Nothing works
Does it say Philips and then go dark? If so, try pushing the reset button. Mine did this yesterday, because I did a complete erase. I had to push the reset a couple of times, then it started working again. I'm back in business, and listening to my songs as I type this.
Is your battery charged fully? Did you let it charge via your computer?
Jun 29, 2008 | Philips GoGear SA3125/37 MP3 Player
Temprature Gauge needle is in the red
I would replace the thermostat first
Jun 04, 2008 | 2001 Ford Focus
T-Mobile Sidekick ID Cellular Phone Logo
100 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
