Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Refrigerator failed keeping food cold, ice maker stopped working
Ammana refrigerator side-by-side unit,
Model SQD26VW
mfg # P1315203WW
ser. no. 9805255800
Very weeak in producing cold, ice maker stopped working
compressor casing is very hot
fan working but air from the fan is not warm
  • Anonymous Mar 17, 2014
    Unit has bee plugged in for 2 days, no ice and today started to have a lot of condensation in the refrigerator, all the coils are wet with condensation. Never had this problem before.
    President:
  • Amana Master
  • 2,651 Answers
I would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Posted on Nov 16, 2008
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a GE monogram side by side refrigerator; the refrigeration side is not keeping cool and the freezer is not quite as cold as it typically is, though it makes ice just fine. There is no visble ice on...
if its making ice and if the coils are some what clear .. i would look and the air dampner . that controls the air flow to the fresh food area , this is a common failure in the ge .. mm there is a up date kit for this .. see your parts dist in your area .. wou will need the correc and complete model #` and ser # of your unit .. mm hope this helps feed back pls ..
Jul 10, 2011 | Refrigerators
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
348 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
