Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
Xm2go direct entry tuning problem
I cannot punch in a station number anymore. Any number I hit tunes directly to channel 1. Also there is a "B" and sometimes "B-???" next to my antenna strength readout. Is this problem due to the revised channel lineups?
Thank you for your help.
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Posted on Dec 26, 2008
How do you set up an SP-813 indoor TV antenna?
There's not a lot to this antenna; nor much in the way of knowledge required to set it up. Connect a length of coax cable from the F type screw connector on the antenna. Connect the other end to your TVs antenna input. Plug in the power adapter. Switch on the antenna and set the gain adjuster to the half way position between min and max.
Now look at your neighbours properties. Which way are all their antenna pointing? Point yours in the same direction.
If you know what channel on the tuning scale the local TV stations use for broadcast then tune your TV manually. Then fine tune gain and direction of the antenna for best reception. If you don't know the tuning channel it's a bit more pot luck. Let the TV do an auto tuning and hope you have not too much or not too little gain and the antenna pointing in the right direction.
Sep 03, 2014 | Televison & Video
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Aug 05, 2010 | Axion AXN-8701 7 in. Portable TV
How do i change the channel
Hello restart90,
1) Press BAND to select between XM DIRECT, XM1 And XM2 bands.
2) Press TUNE << or TUNE >> to select the next higher or lower channel. Press and hold to advance quickly.
3) Press BAND to select XM DIRECT. Enter the desired channel number by using the preset buttons 1-0, then press FUNC for 3 seconds to confirm the channel. Display will show "CH---" if channel is not available and the current channel will be retained.
Hope this helps.
Oct 17, 2009 | XM Radio (XMP6000)
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Direct TV ''Program not available'' but should be
Define "Lost." if you manually tune to the channel, whats there. By manually tune I mean punch in the channel number on the remote itself instead of using the guide or channel up/down buttons.
If the channel is there but not on the guide, you have set a custom guide and would need to go into your guide setup to change it back to "All Channels."
If you do not have apicture on the missing channel, reply back with the channel number and the error message at the bottom of the screen.
Mar 22, 2009 | Directv D12-300/100 DTV Receiver
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Matsui TVR 190 Combo VHS/ TV
in the main menu select Ch tuning by pressing PALY OR STOP then press enter.the tunig screen will appear
press F fwd and when a clear picture is found pressENTER then the number of the channel that you have found. Press ENTER to confirm the channel number. the number will stop flashing. repeat stage 2 until you have found all available channels. press MENU button to exist the menu.
Jan 14, 2008 | Televison & Video
Setting my preferred stations
you need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
Jan 08, 2008 | Audiovox XCS9 XM Radio Receiver
Suddenly cannot tune
Reset everthing in the menu. Mine does this every few months or so. I scroll thru the menu option until a come to a reset thing.
Dec 18, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Cannot get to tune one station to next station
Does the radio have a full subscription? Next, check the "Preset/Direct" button and push it until "direct" is lit up. Then you can directly enter the channel number. Also, you can go into the MENU and set what channels to skip and jump to. My guess is that you bumped the "Preset/Direct" button and your radio is in "PRESET A or B or C" - you need direct. Try that first, than get back to me - okay? BTW, I'm assuming you're talking about an XM satellite radio like the one in the photo?
Oct 28, 2007 | Delphi Roady SA10035 XM Radio Receiver
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
147 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
