Question about Wharfedale PowerCube PC-12 Subwoofer
Ticking sound I have wharfedale powercube 12A. It was working fine for about a year then I started hearing some ticking and popping. It kept increasing with time and now I only hear the popping and ticking sounds. Can someone help. Thanks
SOURCE: Wharfedale Powercube uncontrollable loud noise
Change the 2 elco's in the supply
6800µF 63Volt
Posted on Mar 02, 2010
0 characters
1 Points
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
Where do i connect the single rca plug from my pioneer home theatre sytem
usually it will go into the white plug on the back. if one of the rcas is labeled signal or LFE this is the one to put it into. let me know if you need further assistance.
Jun 14, 2010 | Wharfedale PowerCube PC-12 Subwoofer
My subwoofer makes a very loud shreaking sound consisting of a mixture of high and low tones (almost sounds like it is about to explode) after power has been on for about 5 minutes. I had the problem...
Did they charge you much for that 'fix'?
Though it may have become damaged in the original problem, the driver won't make loud sounds by itself in the absence of a signal. The internal amp is probably malfunctioning and it is very capable of destroying its own driver. Don't let it continue when it starts acting up.
Did it work correctly for more than 5 minutes after the driver replacement? Take it back and make them do it right this time.
I had a powered sub amp problem that the local guy couldn't fix so I just disconnected it and wired the driver directly out to a separate amp. Works fine as a passive sub.
Jun 11, 2010 | Wharfedale PowerCube PC-10 Subwoofer
6800µF 63Volt
Aug 01, 2009 | Wharfedale PowerCube PC-12 Subwoofer
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale dab radio da-110e
According to the manual the indicator lights go out when the batteries are charged.
Mar 16, 2008 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale Subwoofer problem
Take it to the shop from where you purchased it or try to web to get further information on their service outlets in your part of thw world. The problem is not a formidable one. It seems the IC in the Subwoofer and would not take more than half an hour to solve the problem. If it is under warranty get it replaced as well as the cables. Do not try to repair this yourself unless you know something about speakers and sound systems.
Sep 03, 2007 | Wharfedale PowerCube PC-10 Subwoofer
do the fuses blow no matter what volume you are sending?
May 25, 2007 | Wharfedale PowerCube PC-10 Subwoofer
Wharfedale PowerCube PC-12 Subwoofer Logo
122 people viewed this question
Top Wharfedale Speakers & Subwoofers Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Speaker and Subwoofer Expert? Answer questions, earn points and help others
