Question about Jenn-Air JJW9627C Expressions Collection Electric Double Oven
Jenn-air oven cleaning instructions
Lost the owners manual. How to clean a JJW8627aab.
  • Anonymous Nov 26, 2008
    How to clean the oven?
  • 1214 Answers
SOURCE: Jenn-Air elec oven finished self cleaning, door locked,F3 error
Go here to get the manual -
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf
Posted on Jan 22, 2009
  • 833 Answers
SOURCE: jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Posted on Dec 07, 2007
SOURCE: Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Posted on May 08, 2008
SOURCE: jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on May 10, 2008
eagle338
  • 4889 Answers
SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Posted on Nov 07, 2008
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
I cannot find my owner's manual. I need to clean my oven, but I don't have the instructions and the lights have gone off on my panel.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 05, 2011 | Jenn-Air Ovens
How do you set the oven to self clean. Lost instruction book
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I lost my manual and forgot how to start the cleaning process of a double oven by Jenn-Air
It is a good thing that you lost that. Self clean is a no no. Ruins the controls
Jan 23, 2010 | Ovens
I've forgotten how to use clean, please help
Here's a link to the Jenn-Air web site with a free owners manual that you can download.. They have two different ones listed, so rather than post a direct link to the manual, I post the link that will allow you to select the correct one for your oven.
You need a couple more letters added onto the end of your model number (either a AW or CW) to determine the correct manual for your oven.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JJW8530C&siteCd=JA_EN_US
Hope you found this very helpful and best regards!
Aug 07, 2009 | Jenn-Air JJW8530C Expressions Collection...
CAN BARLEY READ THE DISPLAY
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Jenn-Air JJW8627C Expressions Collection...
Jennair s136 drop in range
I have a Jenn-Air S136 and need instructions on how to clean the oven.  Can someone point us in the right direction?  Thank you.
Jan 19, 2008 | Ovens
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW9627C Expressions Collection Electric Double Oven Logo
840 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
