Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
How to thread my machine
I purchased a second hand Brother sewing machine and it appears to be in very good shape. I am just trying to figure out how to thread it. Please help
I did not have a Serger, all I have is an old sewing maching but appeared to thread from the left slot and any machine that I have had always threaded from the right side. Anyway, I found a neighbor who was able to figure it out. I would love to get a directional book for the machine if that was possible. The machine is a Brother Model No. VX581.
Posted on Nov 16, 2008
My Brother HE 1 will not feed the top thread. When I embroider, the thread never comes off of the spool. I have rethreaded the needle, it is correctly threaded.
I don't have this particular machine, but have you made sure that you are threading correctly? I would completely remove your upper thread and put on a fresh needle. Also, whenever you do make a thread change, be sure and cut the thread at the spool on top and then pull the thread from the bottom (needle area) This will help prevent any fraying in the thread path that you can't get too easily. If this isn't an embroidery only one, try just sewing first so you will know if it feeds. It it does work in sewing mode, some machines are picky about thread. Here is a link for the path: http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_he1eus&ftype3=2076&faqid=faqh00000007_000
May 17, 2017 | Brother Sewing Machines
I have just purchased a second hand Singer 6038. When sewing, the machine hesitates about every 15cm of sewing causing the stitch to go off centre. The tension is fine whilst trying various stitches.
I'm wondering if there is a possibility that a puff ball is getting in the tension, needle or bobbin. You might want to look at your thread in the light to see if it is fuzzy. Replace it with good, embroidery thread from someplace other than Walmart. Anyway, do a good cleanup in those areas to ensure there isn't buildup of thread.
Nov 28, 2016 | Singer 6038 Mechanical Sewing Machine
New CE5500PRWBrother. having trouble threading the top. the thread take up lever does not protrude enough to thread the thread through the hole. have read and re-read the manual. can't figure out what to...
Have you tried hand winding the fly wheel towards you to bring the take up lever to the top of its cycle to thread it?
This does sound strange as most computerised machines the machine would stop at the top of the cycle so this should not be necessary. Is it possible that it has been damaged in transit.
Best solution is probably to ring the shop where you purchased it and talk to their sewing machine person about it, certainly if it is a fault it should be under warranty.
And if it is just a case of you learning how to use the machine, a reputable shop should always be happy to answer a question or spend five minutes showing you again how to thread the machine.
When I purchased my last machine, I think I spent an hour there having a demo first time, then went back again with questions and my fabric to test sew myself before buying.
Apr 08, 2011 | Brother CE5000 Computerized Sewing Machine
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Missing brother PS 53 sewing machine foot pedal where can I purchase a second hand one
i just got my brother sewing machine serviced and they replaced what needed to be replaced(spotlight in australia)
Aug 29, 2010 | Brother LS-1717 Mechanical Sewing Machine
I have a Brother LS-1717 Sewing Machine, it was given to me, without the manual. My thread keeps jamming and the thread is lose on the fabric. Also I have these dials on the front and I can't figure out...
You really need a replacement manual and Brother is excellent about providing them. Go to http://www.brother-usa.com/manuals/ if your machine was sold in the U.S. If not, you'll need to contact Brother International.
Loose thread and jams usually mean the tension needs adjusting. If the loose threads are on the underside of the fabric, it means that the tension on the top thread is too loose. Be sure to have the pressure foot down when you adjust the tension and only move the dial a tiny bit at a time. Also, when you begin sewing, hold the top and bobbin threads securely in your left hand for the first few stitches. That bit of tautness helps prevent 'birds nests'.
Hope this helps!
Robbie
Aug 10, 2010 | Brother LS-1717 Mechanical Sewing Machine
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Machine sews with huge loops on bottom and top of fabric
This is why I think sewing machines should be bought from a local dealer who knows 98% of the time this is operator error and will take the time to show the customer the proper way to thread the machine. The other 2% of the time they could fix it or exchange for the customer. The problem is in the threading of the top thread, refer to the manual. No one on the phone or in an email can guide one to thread a machine. Diagram in the book is a poor second to hands on instructions given by most independent sewing machine dealers
Nov 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
179 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
