Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam DP-02 I have the DP-02 i get a error messages ( S reset err: 12 please power down ) when it is booting up. does anyone know how to fix this problem is there some firmware software i can downlod to fix this.
I had the same message on my DP02 error 12 please power down. I went to an electronics store and asked a computer technician and he said it probably isn't getting proper power to start up .We looked at the manual specifications for power and found it needed a power adaptor which has an output of 12 volts and 2.5 amps which is 2500ma. Once I put that adaptor on it everything powered up and it works great.Look for an adaptor that says output 12v 2500ma and it should work fine.
Posted on Jan 03, 2009
  • 189 Answers
The problem could be that the drive isn't getting the proper level of power to spin all the way up. Things to check would be the power adapter first. If that seems ok checking the power source from the wall might be what's needed.
If power looks good, the problem could be due to some corrupt sectors on the hard drive which can be caused from improper shutdown or bumping (or even vibrating) of the unit while running. I say vibrating because I've heard of cases where vibrations from a subwoofer placed to close to a digital HD portastudio have caused such problems).
Hope this helps.
Posted on Nov 17, 2008
Hi! I have just bought a Tascam Studio DP-02 (with a third party power supply) And when i powered it up, after initialising it reads "NO HDD20: PLEASE POWER OFF" anyone help?
It looks like it doesn't recognize the hard drive, this is usually since the power supply is not strong enough, please check the specs on the power supply.
According to some info I found it should be:
12V and 2.5A (some sites even report 3A) so 30 to 36W
Sep 04, 2017 | Tascam Audio Players & Recorders
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Hello : I have a Tascam portastudio_dp_1fx. Anyone knows how to reset this message: Err: 12 Please PWR OFF
This error will only dis appear when you replace the ac power adapter that comes with it.
Or you better check if the output voltage and the amperes are not dropping.
Your power adapter should out with 12 volts and 2.5 amps. Less of this value means its dropping and its not stable..
You can use a multitester to check if the output voltage and amperes did not meet the requirements.
Hope it helps!
Dec 31, 2010 | Tascam DP01 All-In-One Recording Package...
On my Tascam DP-02 I am recieving an "error 50" message telling me to re-boot
I called support concerning the same problem and they advised me the only solutiion is to restore the DP 02 to its initial factory settings (Track Edit, cursor up, and power on simultaneously until the Dp asks Are you sure?) This will erase your hard drive. I've had this machine for less than two months and I'm really disappointed. Prior to this latest episode the DP would not let me load two songs, telling me File Error 1005 FF (Pwr off).
Jun 14, 2010 | Audio Players & Recorders
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
TASCAM DP-02 (You don't even include it here in your products!)
Here's a link to the DVD tutorial for the DP-02:
There is also a video on Tascam's support page for this product that you can download for free:;9,16,3580,19.html
You can ask questions here or consider joining Tascam Forums (I think it costs $4) and talk to Tascam experts from all over.
The DP-02 operates almost exactly as the DP-01 did, so manuals and videos for one should pretty much guide you correctly when applied to the other, but the video in the first link is the correct on for the DP-02.
Hope this helps.
Best of luck.
May 08, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam Portastudio DP-1FX/CD When I turn it on I get this message. Err: 12 Please PWR OFF
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Apr 22, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02 error 50:0
this happened to my dr-1 what i did is took out the SD card, used a card reader to put all the songs from the music folder onto my laptop, then erased the songs from the card, reinserted it into the Dr-1 and no more error.
hope it helps. tascam doesn't come with a card reader, they use a usb but i've found that a card reader is faster and easier to manage. you can get one anywhere they sell electronics for about $15. cheers
Mar 16, 2008 | Audio Players & Recorders
Tascam DP01 All-In-One Recording Package Microphone Logo
1,391 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
