Question about Dell Inspiron 1000 Notebook
My laptop shuts off after running serveral hours on line
I bought it used and its fine when i use it off line. I just bought a internet adapter from sprint so i would have the internet. but when I go on line it shuts down after several hours.
    Genius:
  • 1,913 Answers
May be your system is malware infected scan your system with nati virus
avst is good pls updateafter install.
i give u link
http://www.download.com/Avast-Professional-Edition/3000-2239_4-10181058.html
then update then scan i n boot time
Posted on Nov 15, 2008
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
Lenovo y410 laptops turns off suddenlty while using it for long hours
hi
is the computer dissipating excessive heat from bottom ? is the heatsink fan working (is it blowing out air from fan on the side ? if not, then replace the heatsink fan. This shut down occurs to advise you that something is not working well , and to avoid damage to the CPU and/or mainboard, its letting you know that.
if the fan is working fine-- are you on the computer while the AC adapter is NOT plugged in ? Are you fully charging the battery before you use the notebook without the AC adapter ? If you are NOT using the AC adapter, running on battery life only, then do this : shut down the notebook, disconnect the power adapter, remove the battery back up from rear of notebook.
reconnect the AC adpater and start the computer -- perform normal function on the computer, run it and work with it for a few hours. if the same issue occurs, (unwanted shut down) , then perhaps the AC adapter is faulty, which is not charging the battery to full capacity.
let me know what happens-- i'd appreciate your feedback w/o receiving bad rating
Nov 15, 2010 | Lenovo 3000 Y410 Laptop
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Laptop will not connect to the internet even though server says there is a connection, dell say it's a software problem and i need to pay, is this a fix?
Check Your Network Adapter setting manually set TCP/IP according to your network Also try to set Default Getway and DNS Server setting.
Mar 11, 2010 | Computers & Internet
Dell XPS Desktop with wireless adapter will not communicate with the Internet. Signal strength excellent, no communication. Laptop with wireless works fine in same physical location. Linksys unable to...
Yes, XP Pro SP2 tends to give a network or browsing issue. Check proxy server settings as well or Apply the DNS staticly to the Wireless Network Adapter's TCP/IP properties and see what happens???
Jul 27, 2009 | Computers & Internet
Connected to Linksys Wireless G ok, laptop rebuilt, now can't connect
I'm a little confused about the status of your network adapter. Can you check to make sure your wireless network adapter(s) (wireless and physical) are set to "Obtain an IP Address Automatically" and to "Obtian DNS Automatically".
After this can you reconnect to the wireless network? Try the internet. If the internet still doesn't come up flush your temp files, close the browser and retry the internet. If it's still a no see below:
If so, can you try and do some simple "ping" diagnostics?
Open a command prompt:
1. Click on the START MENU and select RUN
2. Type in: cmd
3. Click OK
4. Type in >ping <ip address of wireless router>
Example: >ping 192.168.1.1
5. If your results are 4 "request timed out" then you have not established a wireless link yet. I would try and do a factory reset of the router and start over from scratch. A factory reset can be done by simply holding the "RESET" button on the back of the router for about 20-30 seconds.
6. If your results are 4 replies then you can run the next test.
7. Type in >ping 4.2.2.2
8. 4.2.2.2 = a public DNS server. If you get replies then your are on the internet, but it appears that name resolution is a problem. All this means is that when you try to go to www.google.com the DNS server that you should be contacted to find your way isn't able to tell you what the actual IP address is of www.google.com and so you go nowhere.
9. Provided you're set as a DHCP client (meaning your network adapter is set to "Obtain an IP address and DNS automatically" it means your wireless router (if it's the DHCP server - this is the default configuration) is giving you the wrong information for DNS.
10. I would contact your ISP for the correct DNS servers and make sure they are configured properly on the Router.
11. You can see what DNS servers you are actually getting from the Router if you run the following command from a command line: ipconfig /all
Hope this is helpfull.
Let me know if I can help any more.
MO
Jul 07, 2008 | Linksys Wireless-G Broadband Router
Dell Inspiron 1000 Notebook Logo
35 people viewed this question
Alun Cox
