Question about Thomson LCDB 03B 27 in. Television
32" lcd after a while picture goes to negative (inverted colour) somtimesd on power up also
I have a Techwood 32" lcd modl:LCD3211 I also think that it's a Wafdale re badged, as mentioned tv can be on OK for about 20mins and then goes to a rather unwatchable negitive effect (all blacks go blue, softer blue goes to vibrant white) did the usual "shock test" picture comes back somtimes for the rest of evening somtimes for about 20/45mins. there are times when set is turned on it gives the problem. Any one with ideas or help, I'm thinking it may be a dry joint but rather than go over the whole set with a iron, thought I'd ask first.
  • David Butler Nov 29, 2006
    Reason for thinking tis a Wharfdale is, if you look in the Argos cat, there 32" Wharfdale is the spit of the Techwood (cabenit/stand/power light on bottom panell). And when searching for the IR code for the old sky remote, after hours of pulling my hair out both with sky interactive and a very lenghty web search I thought I'll give the Whafdale codes a try. BINGO it worked!!
    Now we have a ProntoPro aswell and just out of curiosity I thought I'd give that a go with the pre-prog memmory and this worked to.
    If you mannage to cop hold of a service manuel let me know.
    Cheers
  • Anonymous Mar 19, 2014
    The picture is okay when the contrast is VERY grey but if you turn it up or the brightness down the black bleaches to white with a little bit of yellow. Any ideas?
I allso have a techwood lcd3211. just wondered why you migh think its a wafdale re badged, i am tryng to get mine fixed but no one can get hold of a service manual for this tv. i know they are currys own brand but no one seems to be able to fix them without this manual. currys dont want to know s warrenty has run ou. any information you might know would be appresited. cheers.
Posted on Nov 27, 2006
Monitor comes on and goes right to a black screen like the power was turned off but the power light is still green.
hi,
You have to check the back light of your lcd monitor. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
May 06, 2011 | LG Flatron L1511SK (Black) 15 in. Flat...
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
HI There, I have a TCL PDP42U3H, voltages on power board are within specs. Getting full picture but very dim with lots of background noise, colours seem to be like inverted like looking at a negative with...
I was a little confused as the model is a Plasma Screened set and you wrote LCD. Not to worry. In the old days, people were told that the display on plasma screens needed to be "re-gassed", this is nonsense. The gas goes no where and is inert anyway, made up of elements like neon, argon and a few other choice U/V emmiting products.
I would say you have a power supply problem in conjuntion with a video pedastal problem. The plasma screen has a half life of some 17000 hours, which is enough for ones eyes to turn square. Thereafter the same again until the picture dulls dow to a still acceptable level.
The supply voltage is not the critical one it is the bias voltage on the video processing that is all important. Do you remember the old colour TV's with pedastel problems and negative/inverted colours, (ITT CVC9 comes to mind instantly here).
If you have a service manual, check the waveforms around the video processor for inconsistencies, if you haven't it is a workshop repair anyway but without a manual you have no real way of knowing what you are looking for.
Hope that sheds some light on your problem.
Nov 03, 2010 | Panasonic TCL42U25 42 in HD-Ready LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 21, 2010 | Westinghouse LTV-37w2 HDTV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Techwood LCD TV - picture fault
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Mar 29, 2017 | Televison & Video
Thomson LCDB 03B 27 in. Television Logo
502 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
