Question about Canon imageCLASS 1100 Laser Printer
Distinguished ring on image class 1100
The ring is two short and one long
  • atsofec May 11, 2010
    I can't get the Canon ImageClass 1100 to pick up a fax with one telephone line with a distinguished ring of two short rings and on long ring. How do I program the machine to pick up the ring?
    Scholar:
  • 117 Answers
Check the menu under additional functions, fax settings
Posted on May 07, 2009
How do i get a dell inapiron 1100 to recinize usb
Question is somewhat vague, but make sure you have the latest chipset drivers installed. This usually contains USB drivers that allow your laptop to recognize USB devices. Go to Dell.com and under "support" you can distinguish the drivers you need based on your laptop model (and even your service tag).
Jun 17, 2014 | Dell Inspiron 1100 Notebook
Express messenger number of rings
This is a "Class Of Service" function. The out-ot-box default setting is generally 3 rings. However, different extensions can be set to each forward to VM after differing number of rings, but each phone will need to be assigned its own specific Class Of Service and the Call forward timers defined accordingly in those classes of service. Normally your system manager will define several classes of service with different forward-no-answer timers then assign those COS to people who request specific call forward timing. The default is usually 3 rings. Hope this helps
Mar 10, 2014 | Mitel Superset 4150 Phone
Need to know how to distinguish between big fish and small fish on myfcv1100l
Only experience will help you, try to turn down gain and up frequency to see differences.
A big fish shows up big!
JB
Jan 03, 2013 | Furuno Fcv 1100 10.4" Color Fish Finder
I have a jewett set up on 4355 fax & phone when some person rings me it goes to the fax instead of the answering merchine can some one help me set it up please
Check with your phone company if you have distinctive ring assigned to your fax
Ringing is having difficulty to distinguish if it is a ring for fax or a ring for call.
if you phone call is 2 rings then set the fax ring to 6
check for distinctive ring from your phone company either double rinfg,triple ring or quadrouple rings
I hope I help you a bit
Thanks
Mar 28, 2011 | HP Officejet 4355 All-In-One InkJet...
We changed our telephone package last week, eliminating the dedicated fax line to one multi-ring line. The faxes aren't coming through now. Any suggestions?
You will have to set the Multi-ring pattern in the Printer Fax Setup to distinguish between the phone ring and fax ring
Press Setup button
Scroll to Advanced fax setup ( Press OK )
Choose Distinctive Ring Pattern ( DRP )
Set the multi-ring you have been assigned for Fax
Press OK -
Try dialing the no., the Fax should ring
Try sending Fax or Recieving, it should work.
Also, Turn off the ECM
under SETUP - FAX Settings - ECM ( Error correction mode ) - Turn it OFF
Jul 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
Set at the Nokia 1100 phone to do what Aeshetal
Now you can turn your nokia 1100 as:
THE DETECTIVE TRICK (Mobile Spying)
Now you can spy on anyone using your cellphone. Just do the following.
1. Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"
2. Short-circuit the left middle and right pins on the bottom of the mobile phone with all connections touching each other this will activate profile "Headset".
If you cant do this just keep your earphone connected to mobile.
3. Now place it under a table in a room and call it. Now you can use your phone for checking out what people are talking about in a room. Just call on your phone.
4. The phone receives the call without ringing and you can listen to what people are saying.
May 09, 2009 | Directed Electronics 1100f Ford Pats...
Creating a ring using two circles in c++ program
Nice try!
If nobody has helped you since September 2008, when you asked the question, you probably scored a "zero" in your computer-programming course, and probably don't need an answer to your "homework" assignment.
Sep 15, 2008 | Computers & Internet
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Canon imageCLASS 1100 Laser Printer Logo
old marine
old marine
