Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Not able to install any software on my PC having Windows XP
When I try to install any software on my PC I get Error 1500 that Windows Installer Service is not available , Another installation is in Process.
I have already used CCleaner Registry Cleaner but it didnt helped much and also try to install in Safe Mode but it failed too
Can you suggest any solution
Thanks in Advance...
  • hunk_guy2002 Nov 15, 2008
    Pls suggest something else It didnt helped still continue to get same problem
  • nidhi_raj541 Mar 21, 2009
    can't install vs 2008 on my pc due to windows installer problem
    Genius:
  • 1,913 Answers
Install windows instaler from here.
http://www.softwarepatch.com/windows/wininstallnt.html
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 15, 2008
    reformat your system.
    clean your hard disk and install windows xp again.
Microsoft Windows could not start the windows installer service on local computer error 3: the system cannot find the path specified
What is the Operating Software? If It XP SP1 or 2 you have install windows installer version 3
Sep 04, 2014 | Computers & Internet
Tip
How to Fix Windows Update Error 0x80070420 in Windows XP
If you have Windows XP and are receiving the Windows Update Error 0x80070420, please follow the steps below to solve it.
First, Check to see if you have Windows Installer 3.1 installed on your computer. To do this follow these steps:
1) Click on Start, Control Panel
2) Double-click on Add/Remove Programs
3) Search your Program List for the program : Windows Installer 3.1
3c56727.jpg 4) If you find it there, click on Remove to uninstall it. Then reboot your computer. If it is not there proceed to step 5.
5) Click on the following link to Microsoft's Download Center to download Windows Installer 3.1
http://www.microsoft.com/downloads/details.aspx?familyid=889482fc-5f56-4a38-b838-de776fd4138c&displaylang=en
6) Install Windows Installer 3.1 and reboot your computer
7) Go to Windows Update and try to download the updates again.
Note: sometimes you may also receive this error if Windows XP has not been activated. To read about How to Activate Windows XP, click on the following support article from Microsoft.
http://support.microsoft.com/?kbid=307890
on Oct 04, 2010 | Computers & Internet
Cannot install
This error code only occurs when using Windows Installer version 2.0 and Windows XP or later. If Windows Installer determines a product may be incompatible with the current operating system, it displays a dialog informing the user and asking whether to try to install anyway. This error code is returned if the user chooses not to try the installation. http://www.symantec.com/connect/articles/windows-installer-exit-error-codes-log-files
Dec 20, 2013 | Encore The Print Shop 21 Deluxe Full...
How do i install a software for windows xp on my windows 7
Most of the softwares for Microsoft Windows XP are compatible with latest Operating Systems (OS) of the same company. So you can try to install the software through the installer.
If the installation fails with error you should understand what is the reason.
If the reason is incompetibility with the OS you may consider to install Windows XP Mode on your Windows 7. You can download Windows XP Mode from the Microsoft site. This is the link to the page. You should choose the options from the drop-down menus according your system (32 bit or 64 bit).
Then you will have the oportunity to download Windows XP Mode and Virtual PC.
After installing these softwares and restarting the computer, you could enter Windows XP mode and install your XP based software. I hope this helps you. Good luck!
Sep 28, 2011 | Microsoft Windows 7 Ultimate, Full Version...
No audio on my newly installed xp software
If you can see an error in device manager its means the audio driver is not installed. You need to installed the audio driver. The audio driver is in the CD installer of your motherboard.
Regards
nicoleFIXIT
Oct 02, 2009 | Microsoft Windows XP Media Center Edition...
Msi is not working.
Have you tried reinstalling/upgrading your Windows Installer? Link below...
Nov 17, 2008 | Computers & Internet
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
701 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
