Xion usb turntable for Mac computer
Hi Ginko,I bought a USB turntable and have had problems with sound quality when recording. I have checked and I have set up correctly. The problem is, when I start recording an albumn, the first one or two songs will record perfctly, but sooner or later the record will produce a thick static sound. There is an underlying low buzzing sound and the clarity of sound is terrible. I have tried changing the weight of the needle much heavier and lighter, and the same thing happens. I have also tried old albums and brand new never before played).Any tips....Many Thanks,Mitchell.
  • mitchellvass Nov 15, 2008
    Novelist:
  • 137 Answers
Can you listen to the album through the USB when not recording? I'm asking because it might be that there is a buffer underrun or some other problem that is caused by the computer not being able to code the input fast enough. What are the specs of the mac you are using? are you sure the USB is 2.0? that could be a problem too.
Posted on Nov 18, 2008
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
I have a turntable that will convert vinyls to CDs via a USB port. There are two RCA jacks coming from the turntable. I can not plug them into my computer. Is there a cable that I should get to plug in the...
You may be able to record from the usb cable if your Mac recognizes it. You can purchase a converter plug (online/radio shack) to plug the cables into a mic or input jack on the Mac..
Mar 27, 2010 | RCA NILES 174 Remote Control
Is there a mac os x driver available anywhere for the sony ps-lx300usb turntable?
You do not need a driver for mac... just plug the usb cable into your mac... go to sound settings in system preferences and set USB to default audio input device... then install audicity... it is free and open source... play your record and hit record in audicity. done.
Feb 06, 2010 | Sony PS-LX300USB Turntable
Cant get sound out of speakers when connected to my ion usb turnt
How exactly have you got this equipment set up thanks ???
If you play another song on the computer from a cd original then what sort of output do you have???
Is the sound clear and complete???Bass Treble Mids etc
If the turn table has been set up properly the you will get a signal from the record deck to the computer and head phones too via the mixer.
Next is to check the way sound gets from the usb to the computer
Maybe the USB drivers are required for the computer before it will play correctly.
Try to uninstall then reboot and reinstall.Check again
If this doesnt work then try the make and model of the usb turntable and check to see if there is an updated driver for you computers type or brand or Operating System.ie - XP or Vista
Hope this helps ,let me know if you need more help,
Misterdj
Jan 10, 2009 | Audio Players & Recorders
Converter of audio cassettes to CDs
Get a computer with an audio input or soundcard. Like a Mac with garageband and a soundcard. connect both with a male 1/8" to male 1/8" cable. Press play on the tape deck, record on the computer. Once done, edit and trim the beginning and end. Import to itunes. Create a playlist. Burn to cd. Simple.
Aug 28, 2008 | Audio Players & Recorders
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Computers & Internet Logo
709 people viewed this question
David Payne
David Payne
