Question about HP DeskJet 3745 Printer
Color Printing I have an HP 3745 (el cheapo printer). Even though I've had the printer for awhile I have never been able to print anything in color. It came with a color and black cartridge. Since I've never used the color it should not be a cartridge problem. Is there some secret to printing in color that I might be overlooking? For starters I would like to insert clip art into a document and print it in color then perhaps just print a word document in color. Your help is appreciated. Thanks, Paul
  • 36 Answers
Hi
please restalled the software and go to the Properties options see the color cartridege level and select the level  see there some options. you'll find it.
Posted on Nov 15, 2008
    Problem Solver:
  • 28 Answers
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that pops up, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using.The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click the Setup button. Under Printout , choose one of the color options. (If other options have checkmarks, click in the check boxes to remove the checkmarks.) If there is no Setup button, click the Graphics tab, and then click the Color button. Under Color Control , choose a Color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a checkmark in the box by Print in Grayscale , click in the box to remove the checkmark, and click OK . If you are using Windows 2000, in the Advanced tab, click the Printing Defaults button. Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
  12. If this does not help you may need to update the drivers for the printer.
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
I am printing exterior photos of a buildiing on regular paper for test only. The color is printing out with a green tinge. What is happening?
Not using genuine HP cartridges could be one reason. Low ink cartridges could cause not enough ink to be used to make a certain shade of gray or black and thus causing the green tinge. Also if you are selecting photo quality printing then you need to use photo paper. The printer drivers tell the printer different commands depending on what kind of paper you tell it you are using. Good luck!
Mar 09, 2011 | HP Deskjet 3745 Inkjet Color Printer
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
Hp printer 3745 is printing in green only.
Uninstall your printer software and install it again and try to print again. It should work.. because your printer setting seems to be messed up. If it still does not work then it is recommended that you change your ink cartridge
Have a nice day!
Jan 19, 2010 | HP Deskjet 3745 Inkjet Color Printer
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
Color printing in hp 3745
i need driver deskjet 3744
Sep 29, 2008 | HP DeskJet 3745 Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
HP DeskJet 3745 Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
