Dx4450.New ink put in but won't print
Hi , The black ink ran out on my printer .I put a new one in ..followed all instructions ..shake ink etc etc ....it doesn't work ..it.reads as full but won't print . can't work out how to get it working .I thought about trying to replace one of the other colours to check if it is the inks but can't work out how to get it out . Hope someone can help me ? Thanks Mel
  • mafirth Nov 15, 2008
    Hi, thanks for the suggestion but how do I get the cartridges out of the printer .. ? also I have read that if you take the cartridges out the chips won't work .Is this correct ? Thanks Mel
  • 73 Answers
Hi Mel
unplug the printer--> remove all the cartridges from the printer--> wait few minutes--> plug the printer--> install the cartridges
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Posted on Nov 15, 2008
  • pmgca Nov 15, 2008
    Mel,
    Unplug the printer--> remove the cartridges (as you do to change them) in order to reset the printer---> plug again the printer --> set the cartridges again in the printer--> print a test page
    This process will not damage the chip
Why will my 5520 printer will not print black
IT MIGHT BE THAT THE BLACK INK RAN OUT OF INK SO ITS NOT PRINTING IN BLACK.However try changing the ink cartridge... If you have already done so then remove the ink cartridge and the clean the copper contacts with a lint free cloth... then shake the ink cartridge and then put it back in. then check if it works... if it does not then remove the power chord from the back of the printer without turning off the printer... then press and hold the power button for 30 sec...
then release the power button and then plug in the power chord...
again try printing in black.. if it does not then follow the steps below..
press the setup icon on the printer >> go to tools >> Clean Printhead ...
after it is done again go to setup >> tools >>Align Printer
after it is done check if black prints or not..
if not then Press BL/TL/BL/BL Buttons, in sequence (BL- Bottom Left, TL: Top Left) >>Touch Support Menu>>
Press Right arrow for Reset Menu and Touch OK >>
Press Right arrow for Semiful Reset and Touch OK >>
Wait for unit to Power Down/Turn Off>>
Press Power button to turn the Printer On.
Check if it works or not... if it does not then service the product
Dec 08, 2012 | HP Photosmart 5520 e-All-in-One -...
Error code 0xc19a0023
I went crazy trying to fix my HP D7560, days and days of print ink failure, unable to align cartridges, until to clean print heads. My symptom is that the black ink started to print only in a light gray. I tried everything from running Tools, changing to new cartridges, even buying a new print head (which was not genuine HP, they don't make them anymore, and the new print head would'n't complete in diagnostics without error). I love this printer and didn't want to part with it. So I searched for days and tried many solutions without success. Until I found this one last solution - it my last ditch effort. The solution is to get a bowl of very hot water (not boiling), remove the print head from the printer and place the print head directly in the hot water (sounds risky! but I did it). I watched as the bowl filled with black ink. The instructions said to let it sit for 5-10 minutes, but I couldnt' believe the amount of ink that poured out of the print head. So, I kept replacing the water and shaking the print head carefully in the water to loosen the trapped ink. I repeated this step (replacing water) until it was no longer producing black cloud of ink and water was fairly clear. I carefully dried the print head with a paper towel, let sit for approx 5 minutes to dry some more, shook it vigorously a few times to shake out any water, and then lastly hit it with a blast of compressed air to ensure all water droplets were gone. I put the print head back in, re-inserted the cartridges and the printer ran through diagnostics automatically - aligning cartridges and printing a test page - it was BEAUTIFUL!!!! Until I tried this, nothing worked. I'm hoping this solution will help others. Good luck.
Feb 15, 2011 | HP Photosmart D7560 InkJet Printer
I have put new inks into my printer epson dx4450 and I cant get the black to print? I have tried 2 new black catridges.
Please forgive me for suggesting the most simple of solutions, but.....many times, people forget to remove the tape that covers the ink ports on a new cartridge. If you have already done that, forgive me for thinking in such a simple manner.
Dec 23, 2010 | Office Equipment & Supplies
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
It uses far too much ink when not printing. Let
Your story is common and the best reason to trash this printer and put it down to one of lifes bad experiences.
Cheers
DeJudge
Aug 08, 2009 | Epson Stylus CX6000 All-In-One InkJet...
We repalced the black ink cartridge but it wont print black
Most ink jet cartridges have "multiple" protectors to keep the ink from leaking or drying out and the electrical connectors from getting damaged before they are installed into the printer. You should be removing a plastic cap device for the ink, and typically, a piece of clear tape that protects some copper traces on the back of the cartridge. Make sure both are removed. If it still does not work take it back to who you bought it from and have them check to make sure there is ink in your new cartridge. Typically, you can shake it and hear a liquid sound. Good luck.
Toby White-Beebe
Dell Certified Lead Systems Expert
Jul 08, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson DX4450 printer
What about it? Huh? Give us a clue will ya? You want to know how to do it? When to do it? Or are you telling us you are doing it?
Put some detail in your posts please. And why post it under a generic problem for all printers. It's fairly obvious your problem relates to an Epson DX4450
Jul 16, 2008 | Office Equipment & Supplies
Vertical lines throughout photos
Solution: Clean The Print Head Nozzles (Windows) MP500 / MP800
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleanings or print head deep cleanings. nozzlecheckflow_en.jpg
Dec 19, 2007 | Canon Pixma MP500 All-In-One InkJet...
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
