Buzz from lexicon lx-7 power amp
Hi i have a problem wit my lexicon power amp, a buzzing/hum coming from all the channels. Its only very faint when its just the power amp on and nothing is connected to it but the speakers. buzz gets louder when i connect the pre amp to the RCA inputs on the power amp. it get even louder when i switch the plasma on. which is connected to the pre amp with a component lead, if i disconnect the component the buzz is reduced. Is there a fualt with the power amp as i'v treid loads of ways to get rid of the buzz.
  • Audio Player... Master
  • 5,391 Answers
Might be caused by any of the Large Capacitors in the power supply section of the amp.
Posted on Feb 16, 2009
I have kenwood amp m-a100 which has loud buzz / hum on all channels and distorts radio very badly can you help ?
The loud hum will be probably caused by the Large Electrolytic Capacitors in the Power Supply section. All of them will need to be replaced to be on the safe side. The buzz noise is caused by the fact they are letting in the 50/60hz mains. Hopefully that should clear everything up.
Sep 09, 2014 | Audio Players & Recorders
Mackie DL 1608-1 channel hums w only 1 guitar
Generally the hum is one of two things. If a sensor, pickup, per-amp, or mini-amp are too close to the receiver or speaker, Feed-back may occur or a hum and buzz join the audio signal out. The usual problem is: line in port on the instrument can be defective or the male jack is not making proper contact. If a cord is tested and working, the condition is in the input on the instrument. If a terminal has a loose wire inside the instrument the problem can be intermittent ( come and go) and thus a buzz or line noise may be present.
Dec 15, 2013 | Audio Players & Recorders
One bad channel
The thing with stereo amps is that they are actually two mono channels put together, so if one side goes you have the other side to tell you what the other side should be doing. So you can compare the good channel with the bad. For example taking voltage readings. Also you can buzz test it. Generally you can touch with an insulated tool parts of the amp to produce a buzz. So if it buzzers in the good channel it should buzz in the bad. When it doesn't you have found the bad part!
May 18, 2013 | NAD C160 Amplifier
Can't route effects to two channels of my mixer. If I plug into input 1 of my power amp, I have effects. If i plug into input 2 of my power amp, I get no effects. I tried both Crown and QSC power amps. ...
The power amp is the final stage - the last output from the mixer goes to the power amps.
Its a routing problem - some mixers only allow certain routing and this could be affecting your FX routes.
All the FX - internal or outboard come before power.
Check the manual Check the aux send and returns Check if you need need stereo plugs for the send and return of FX.
Get back if still stuck.
Feb 26, 2011 | Lexicon MX400XL Dual Stereo/Surround...
I have a hum/buzz when i turn on my studiomaster vision 8 amp, all the volume and channel sliders are down, i have had this problem before and it went away for a while and now its come back, i can play all...
Yes it almost certain to be the big Electrolytic Capacitors in the power supply. What you are hearing is the 50/60hz mains hum they are supposed to take out. Don't know the amp in question, but this is common problem with all amps. You can't miss these. But be care full they can hold a charge! There might be just one big one or more. At the least 2,000UF. Replace all.
Jan 26, 2011 | Audio Players & Recorders
0ne channel sound other very faint
You still need to determine if the main amp is at fault, before takling the turntable. Does the amp have seperate sockets for the turnatable, if yes then inside the amp it will have a pre-amp just for the the deck, which no other device will go through. This can be easily tested. First find it, by tracing the wires from the phono imput to the first PC Board you come to. This should have the pre-amp on it. Touching the left and right inputs (one at a time) to it should cause it to buzz. If they buzz at the same volume it's OK. If not there's a fault on it.
If that test is good then the turnatable is to blame, starting with the obvious fault of the cartridge. Other faults include broken or poor connections, plus a fault in a pre-amp on the turntable. You can test this by the same method as above.
Nov 30, 2009 | Audio Players & Recorders
Crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
May 19, 2009 | Lexicon LX-7 7-Channel Amplifier
Carver PM900 power amp with hum/buzz
1-shut down all flourecent lamp and check.
2-check for your cables in a good condition and no touching of wires to the body of amp.
3-connect(ground loop isolator)code number(270-054)from radio shack near you and connect it between your audio device(like cd player and amp)
Apr 15, 2009 | Audio Players & Recorders
Lexicon Lx-7 buzz sound
Hi chupetin2
If the problem is present with ONLY the speakers connected, that is no other powered devices like subs, or input/output cables, it will be a power supply problem inside the amp. If you have electronic fault finding skills, there will probably be a capacitor in a regulated rail that has failed.
If you do have a sub connected, be sure it is powered from the same mains source as the amp, or at least a GPO that is on the same phase. Different phases will induce mains hum, as will multiple earths. Try also temporarily moving the amp(whilst monitoring the hum) from where it is sitting and see if the hum is being induced into the amp by any other devices
Happy to talk to you more about this. Just ask:)
regards
robotek
Aug 18, 2008 | Lexicon LX-7 7-Channel Amplifier
237 people viewed this question
 Grubhead
Grubhead
