I bought this dvd player without ownr's manual and I don't know if is it region free and how to change region. Could you help me? E-mail: [email protected]
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
Question
Can I change the region code on my player so that I can play DVD / Blu-ray disc from other regions?
Answer South Africa is region B for Blu-Ray DVD and Region 5 for DVD and finding the procedure will be difficult as international copyright legislation prohibits manufacturers from providing instructions for changing the region code.
you will need air in a can and open the unit and remove the laser screen cover that supports the disc when in and blow out the dust in the laser do this a few times.
Possibly in the wrong output mode. (i.e. in PAL-60 when NSTC is needed)
On the remote, press the PAL/NSTC button to cycle through the output modes.
Choices are: NSTC, PAL, PAL-60 and AUTO.
Also make sure the correct TV type is selected in the System Setup menu.
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player. 2. Turn power off and on again. 3. Open the tray. 4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions. 5. Hit OK on the remote.
Open the unit and check around the output jack for the video and check the cables as well If theres a bad connection your gonna or someones gonna need to know how to solder.. if you see the connctions bad and cant do it your self somne repair center may charge you a minimal fee for a resoldering job. Good luck
