Question about RCA HD52W59 HDTV Projection Television
Rca hctv the colors are all out of line. its like it 3-d. the picture is bowen in to the center at top and bottom. SOUND AND ETC ARE ALRIGHT.
  • 927 Answers
Good Day;
I would suspect the fuse near the IHVT, conv. power board or conv board itself. check voltages going to the convergence board. Good Luck, big IRISH.
Posted on Nov 17, 2008
I have a RCA 42"
The YSUS control board has failed from the description given. This is typical of the symptoms presented. It can be removed fairly easily and sent to a repair center to be repaired.
Nov 28, 2017 | RCA P42WHD33 42 in. Plasma HDTV
Turns on with sound but the picture is running colors mostly see red and blue also double vision. 3 colored lines show up on screeen when first turn on
do you have the convergence option in the customer setup menu? is the picture convcave bowed in at top and bottom. if you dont have the convergence option you might have the fl231 fuse problem. or something simular. first read this to determine if you do. if you dont you might have still have a convegence issue http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know i am here to help.
Nov 07, 2010 | RCA HD52W66 Projection Television
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Bowing of picture at top and bottom towards center.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
