Question about Pc Ware M748LMRT Motherboard
Usb connector can u help me with my problem..? i already added a usb connector to the MB. when i try to use my flash disk, windows recognize that there is a flash disk attach to the comp, but.... after that, my monitor goes BSD (blue screen of dead). I try to restart my comp again and try to do the same one. i plug my flash, and then it's goes Bsd again. can anyone help me with that please... Just mail me to my mobo is m748lmrt
  • TweakX May 11, 2010
    Check your solder joints to make sure they aren't touching,check solder joints.
Try disabling "USB Function for DOS" in the BIOS.
It can be found on "Features Setup Page".
Hope this helps...
Posted on Oct 26, 2009
Windows 8 x64 doesn0t show usb flash drive in windows explorer
It will only show USB devices that have been formatted. Have you tried going into the Computer Management, Disk Management to see if the usb drive is recognized? Can another windows PC recognize the USB drive?
Aug 17, 2014 | Electronics - Others
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
My capacity genx 2gb usb chenge to 14 mb.when i connect flash disk i show cd drive added in my computer and capacity my flash disk cheng of 2 gb to 14 mb.plz email
This typically means the drive has gone bad. Try reformatting the USB drive. Some manufacturers also provide diagnostic/formatting tools on their website that might be able to fix it. But likely it will need replaced. Lucky 2GB USB drives now only run $7.99 or less.
Apr 20, 2010 | Computers & Internet
My usb kingston 2gb always say insert disk e:
try inserting your usb to another usb slot., if it doesn't work try restarting your pc/laptop, if it still doesn't work, most probably that your usb disk is already damaged...
Mar 31, 2010 | Kingston flash memory card - 256 MB -...
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site.
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Unable to access thumbdrive
It is possible that windows is trying to assign a drive letter to the thumb drive that is already assigned to another drive. You will need to go to Disk Management to see if the thumbdrive is showing up there and then try to assign it a drive letter.
Feb 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Trouble adding after deleting
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player. - Tha Mp3 Doctor
Feb 01, 2009 | GPX ML648B MP3 Player
Toshiba 2 gb flash drive showing 0 disk space
You can only format these drives in mode FAT16 or FAT32.
Try to format it in FAT32 mode and let Windows choose the default sectors for you. This is the better solution.
As I can see, the operating system recognise your drive that mean the correct driver was loaded.
After a new format whith the correct params if your flash drive shows the same thing 0 disk space 0 disk space used, your drive is DEAD.
It happens if you had unplug your flash drive whithout stoping it by cliking on the icon in the notification window (near the clock), the icon is mini drive whith a green arrow. Allways unplug the USB devices by this because you have the +5 voltage on this connector and if you don't do this an arcking effect happens betwen your device and the connector.
Dec 14, 2008 | Toshiba 512MB USB 2.0 High-Speed Flash...
Pc Ware M748LMRT Motherboard Logo
176 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
