Question about Cell Phones
Broken LED screen for LG CU720
New LG CU 720 dropped and broke the LED screen. I have purchased a replacement, but I can't figure out how to take the phone apart to replace it. Please help. I cannot figure out how to remove a broken screen from an LG CU720 Shine. Can you please explain the correct process?
  • john10471 Nov 22, 2008
    I am trying to repair a broken screen for an LG Shine cell phone. I have remove the plastic cover and now am trying to determine how to remove th bezel around the screen. There are no screws. It appears that the bezel pops off but I am trying to determine if poopping off teh bezel is the right thing to do.
    Sergeant:
    Champion:
  • 275 Answers
I just dont understand one thing ...
when u dont know what you are doing ... why do it ?
there are something which are to be done by profeshionals
but if u want to loose the LCD forever go ahead and do it yourself
just to save some dollors dont loose the complete LCD
now the choice is yours
Posted on Nov 22, 2008
  • 3,037 Answers
Take off the back plate that houses the battery, undo the four screws (possibly more with this model), then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below. Now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a further six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like molding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD.
All you have to do now is remember which screw goes where and reverse the whole process. Good luck and please let me know of any specific questions you may have when tearing it apart and I will respond as soon as I can. Please be patient if I don't get back right away
Best
Posted on Nov 15, 2008
    Genius:
  • 1,913 Answers
Remove the battery and sim card aslo if memoory card.
then u have to remove soldring from it.
thehn aatch your new screen
then soldring it with wwhere u removed.
    Scholar:
  • 181 Answers
First off the device.before doing any thing.then remove the battery.remove all the screws then all the side locks.
  • fixyy Nov 15, 2008
    Step 1. Take off back cover and remove battery and sim card. Step 2. Remove the six screws holding on the back cover Step 3. Get a thin piece of metal and pry off back piece of the main phone unit Step 4. Once you get the back piece off you can see a green unit at the top of phone. This is the camera, all you do is pull on it and it should unclip Step 5. Once the camera is removed you can see 4 more screws, unscrew these Step 6. Now that the screws are out you can pull off the main board. The first thing you need to do is unclip the black ribbon that is at the top. Then you have to unlip the clip on all four corners, after you do this the main board will come out. Step 7. Now That you have that off there are 2 screws on the back thats you must unscrew. Step 8. With the screws gone you can now pull the slider away from the piece that has the number pad on it. Step 9. On the back of the slider there are 6 screw you must unscrew. The Two screws at the top have small black circles glued on-top of them. Just wedge something under the black peices and they will come off Step 10. Now that the screws are out you can pry off the plastic LCD screen cover from the metal slider piece. Step 11. After the LCD screen cover is gone you must unscrew 2 screws to the left and right of the joystick. After you remove the screws the joystick cover comes off. Step 12. Now that you have the cover off you need to turn the plate where the joystick is on over and pull out of the LCD screen clip Step 13. After you do this you can now put in the replacement and put the phone back together GOOD LUCK
  • 101 Answers
Take the phone apart, you will need a special tool for the screws on the phone, unscrew everything and take not what goes where and eventually you will get the screen out. Other option would be to buy a service manual Haven't found one yet.
How to download PC suit software for lg cu 720
Hello there,
You can obtain the disc from any LG cellphone dealers near your place. You can buy a replacement disc which contains the software.
Oct 22, 2010 | LG Shine CU720 Cellular Phone
Broke screen on a lg shine model cu720 how do i transfer contacts to simcard
HI...
unless and untill you replace your displace you will not be able to trnsfer the contacts to sim.
If you have same mobile with you can check and do by press keys according to this mobile in your broken screen mobile...but you can do by trail and error method only and it may be risky too. but you cannot be sure that you have coped all the contacts to sim
thanx
Jul 18, 2010 | LG Shine CU720 Cellular Phone
How do i reset my LG CU 720?
Reset Default
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select Reset Settings.
Scroll to and select Master Reset.
A confirmation screen will appear, select Yes.
Enter Security code, press OK.
NOTE: The default security code is 0000.
Hopefully this will help.
Clear memory
Scroll to and select Master Clear.
Scroll to and select desired option:
Handset
Memory Card
A confirmation screen appears, select Yes.
Enter security code, then press OK.
NOTE: By default the security code is 0000.
please remember help me by giving me a good rating if you appreciate my help.
Mar 27, 2010 | LG Shine CU720 Cellular Phone
I broke my LCD screen inside my LG Shine cu720. Where can i get a replacement screen?
You can get them on ebay. Here is the link: http://shop.ebay.co.uk/?_from=R40&_trksid=m38&_nkw=LG+Shine+cu720+screen&_sacat=See-All-Categories
Jun 15, 2009 | LG Shine KE970 Cellular Phone
Replaced the screen but there is no image coming up, just a lit up black screen.
if you could see any image from the broken lcd before changing it so your new lcd is not working or no installed right
and if not you may try the cable or the hard shock that broke your lcd effected the main board
May 06, 2009 | LG Shine CU720 Cellular Phone
LG Shine CU720 LCD Replacement Problem
Uh, you should send it back to LG, not ATT. I had the same thing happen to me and they sent me a brand new phone.
Mar 29, 2009 | LG Shine CU720 Cellular Phone
How to unlock an LG cell phone
Google for sites that offer unlock codes for your model you will have to pay a small fee.
Jan 04, 2009 | LG Shine CU720 Cellular Phone
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
