Question about Toshiba 55H70 55" Rear Projection Television
55HX70 The red lamp on the tv was way out of whack as far as doing the convergance. Then the tv shut off, red light still blinking on power button. So i unpluged and plugged back in and when tv came back on it was ghosting and had all three colored lines waving from top to bottom. after reading here I concluded that the IC's need to be replaced. If so is that why the tv shuts off? or is that related to another issue i may have? thanks Rob
  • Rob maxwell Dec 07, 2006
    I had a repair man fix the issue by replaceing the IC's. But now i have three dots in the middle of the screen... blue green and red. The repair guy said that my tubes needed to be replace and it was really expensive. Can any tell if this is true or is there another way to sovle the dot problems. Thank you
  • dgwilson May 06, 2009
    red light blinking on power button. So i unpluged and plugged back in and when tv came back on it was ghosting and had all three colored lines waving from top to bottom. after reading here I concluded that the IC's need to be replaced. How do I do that??
  • 65 Answers
Needs convergence ics period
Posted on Dec 09, 2006
SOURCE:
When i turn on the tv there is no sound only clicking sound and no picture. then it atomaticly turns off. also the lamp light flashing red? not sure what is wrong.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Panasonic PT-52LCX65 44" HDTV
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Picture is distorted with green tint on one side & pink on the other
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 02, 2010 | Toshiba 55HX70 55" Rear Projection...
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Convergence setting is way off
There is a interlace setting if this is set to high it gives that red smudged look please check for that setting in the menu
Jan 04, 2009 | Akai PT4298HD Rear Projection Television
Toshiba 55hx70 projection tv problem
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Jan 20, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
229 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
