Question about Teac Audio Players & Recorders
Protect error on agv8500 - Teac Audio Players & Recorders
Hi there. I have the same unit. A darn nice piece of hardware. A couple of months back I noticed my cooling fan making noise. A few days ago I got the "PROTECT" message and the unit wouldn't power up. I turned it off for three days and it started playing again. Now I'm pretty sure it went into protect mode because it overheated. I just tried finding a Teac replacement fan and didn't see one on the web. My solution will be to adapt a small computer-type fan onto it to keep things cool. It works too well to let it die! Good Luck, Gborchers. GROGSTER
Posted on Nov 29, 2008
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
What is lock protection error for anu script manager
what is lock protection error for anu script manager i have installed anuscrip 6.5 and after instalation i got lock error
Feb 21, 2011 | Adobe PageMaker 7.0 Classroom in a Book...
The TV will not power on and the red light blinks 6 times.
This is a basic blinking error code table:--
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
But in most cases the power cord is "defective" as it's a common issue.try with new cable 1st or else follow the chart and replace the part as per coding chart on main board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Panasonic TH-42PX60U Television
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
3 = Reserved
7 = Total failure
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Read / write error
it is due to the write protect for your drive. If u have protected it by giving read and write protection try to disable them. it will work
Aug 24, 2009 | Kingston StorCase Remote Management...
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protect error
The 'Protect' error means there is a DC voltage present in the output section(which should not be there). This can be caused by a defective output IC(the big IC on the heatsink). Disconnect the IC and see if the error goes away.Also check the resistors around the IC.
Nov 25, 2007 | Sharp CD-BA2100 CD Shelf System
302 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
