Question about Microtek C997SD (Silver) 19 in. Flat Panel LCD Monitor
Power problems hi friends i got a19 inch microtek lcd monitor model number c997sd looks like ween i plug the power suply in to the monitor. but first i have a universal power suply any way ween i plug it the light on the power suply goes off I think there is a short on the power supply board and I think this is a power supply and inverter in one board together. I just need to know if anyone can help me fix my monitor. thank you.
  • Anonymous Feb 04, 2009
    I need a power supply how can i get one? is hard for me to find one for this monitor.
3 Suggested Answers
  • 903 Answers
SOURCE: Microtek 715c power supply requirements.
SuperWarehouse.com just says it requires anywhere from 110-240 volts AC (which isn't very specific) and uses 48 watts. I don't see anywhere online that lists the DC power output... sorry. If you could get a manual for it that might help.
Posted on Aug 22, 2010
  • 414 Answers
SOURCE: I'm buying a Windows 7 computer. Will I be able
You will be able to use this monitor just fine :)
Posted on Nov 03, 2010
Testimonial: "Exactly the response I was hoping for...thanks"
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
Jul 15, 2009 | ASUS VW222U Monitor
Lcd monitor to dvd player
Hi , You need to have external TV tuner card and then you will be able to connect to a DVD.
Jan 11, 2009 | Microtek 815C 18" Flat Panel LCD Monitor
Gateway FPD1960 monitor power suply
Cleaning won't do it.
It probably needs all new capacitors on the board. are any canister looking components bulged up at the tops ? This is the most common problem on the ones I fix.
ebaysbammbammfran
Oct 10, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor makes popping noise when power is on.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 19, 2008 | Microtek 211SD 21" LCD Monitor
Microtek C997SD (Silver) 19 in. Flat Panel LCD Monitor Logo
44 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
