Home | Refrigerators | Your Premium on Ref...
Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Your Premium on Refridgerators..
By IrishDruid on Nov 15, 2008
Dont know if you could see my comment posted after you awarded the Fixya, but I am reposting it here:
OK, in that case, it could be that the ice chute door is frozen or the chute door solenoid is rusty. Look for little rust stains or drip stains on the recess on the freezer door where you put your glass to get ice and water.
It could also be that the micro switch controlling the dispenser is stuck in the 'closed' or on position. If you are familar with fridge repairs, read on, or else, best call the repairman..
First get yourself an ohm meter or multimeter for testing purposes. Remove the hinge cap on the freezer door and disconnect the harness if you haven't already done that. Remove the drip tray from the dispenser area and you should see a couple of screws holding the frame on the freezer door. Carefully remove the frame from the door face because there is a ribbon connector attached to it. You can either disconnect the ribbon or have someone hold it out of the way for you. You should now have a fair view of the dispenser paddles. One controls the water and the other the ice dispenser. The micro switch for the ice dispenser has a brown and slate coloured wire connected to it. Remove at least one of these wires and test the switch with an ohm meter - you should have an open circuit when the paddle is not being pressed, if not then the switch is stuck. You could also visually inspect the switch to see if the button will push in and out. If the switch is ok than you could have a bad relay board, but I would check the switch out first.
Hope this helps
Comments:
Nov 15, 2008
- If the motor is running, then I would think the fault would be a faulty chute door. But that does not mean that the micro-processor or the gears running the auger are faulty.
In any case, I think this is a job for the repairman. (This is the max I can do from long distance:)
Nov 15, 2008
- Well, you can try the "repair service" box at the right to find a repairman near you. (Just put in your Zip code in the box to get a list). Best would be to call around for prices. (maybe even suggest that you were referred by Fixya, and they just might offer a discount ;) The cost of the part itself may not be that much, but repair costs can vary.
Compare the cost of repair (with parts) to a new unit, and if your unit is quite old, then the better option would be to buy a new fridge. However, if your fridge is relatively new and has never had any other problem so far, then its better to get it repaired..
Clarification Request
Posted by miminew on Nov 15, 2008
I think you are right. Prior to posting I did a lot of research and did everything I could find to do. Now I need to decide whether to buy a new ice maker or use a repairman. Any thoughts? Again, thank you so much.
Thank you so much, but I am not prepared at this stage (I don't have a meter) to take the door apart. The motor is running--or at least I have a sound that seems like a motor. But now I don't think the auger is turning. So does that mean that it is dead? Thank you so much for your assistance.
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
We need a new fridge. Saw a Jen Air scratch & Dent model # JF12589 AEP for a resonable... (More)
Answer
which brand of refrigerator is the best?
Answer
I have a ten year old Kenmore 27 side by side self monitoring refrigerator. About a week ago we... (More)
Answer
not defrosting and ice at the bottoms. it also is making a lot of noise after being shut
Answer
i have a general electric side by side model gss22jepaww, it will not dispence water,ice maker... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Refrigerators:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
