Initially, it would work better if you can provide the specific model numbers of the Sony Mini DV Cam and the Archos. Assuming all things even, most DV cameras have an analog A/V video OUT, in turn some Archos with recording capability have an analog A/V video IN. If this were the case, then it would be a matter of getting the right connectors/plugs + cable and/or adapter/interface.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Hi
Thanks for your help, I am not sure on the model number of the camera but know that the archos is an AV700 which will record off the tv / dvd using scart leads but i still do not know what lead to use from the camera to archos......any suggestions. The sony must have a AV out as i can play it throught the TV using a lead provided. obviously ive tried this lead into the archos but the archos will not pick up any signal
My archos power adapter has stopped working and i am having trouble trying to get an replacement. My...
(More)
My archos power adapter has stopped working and i am having trouble trying to get an replacement. My archos is the av700.
I have an AV-700 that works fine, but when you turn off, the hard drive keeps hunting and runs the...
(More)
I have an AV-700 that works fine, but when you turn off, the hard drive keeps hunting and runs the battery down quickly, reset did not work. Andy
