Question about Toshiba 24AF45 24" TV
Remote control problem
When changing stations with the up or down buttons, the channels keep changing on their own. The same applies with the volume control. I've changed out the remote control, but the same happens. Any ideas? Thanx.
    President:
  • 3,130 Answers
Check the front panel buttons . They may be sticking a little Good Luck
Posted on Mar 23, 2007
    Genius:
  • 1,074 Answers
Have your set checked by a repair man this is a chip problem could be the eprom.good luck.
I can change channels by entering the actual channel number on the keypad, but the channel up and down buttons don't work
The up/down button is worn out (guys do this, since we love to channel surf). Keep the original
remote that came with the TV (they're invaluable), but buy a cheap universal replacement remote
(I got my last one at Dollar General for $8), program it for your TV, and surf with that - you'll
get power ON/OFF, channel up/down, and volume control from any universal remote.
May 30, 2011 | Televison & Video
My tv model #27F500T is changing stations all by it self
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
May 26, 2011 | Televison & Video
My t.v changes single the channels, if I am seeing a channel the minute changes to another one
Just a word of thought. Make sure your remote control is not pointing at the TV. Ive seen this many times. A faulty remote control sending out random signals to the TV due to fluid spillage in the remote. Try keeping the remote well away from TV and see if it still changes channels. If not, check the channel up and down buttons on your TV. Do they feel faulty when compared with volume buttons etc? If so, you might have a channel button on the TV that is half stuck in. Hope this helps :)
Feb 14, 2010 | Quasar SP-2723 27" TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Model ws-55711, remote doesn't work but I don't believe it is the remote control, can only change station up or down manually, cannot adjust volume or others manually...
If you can change channels with remote then TV is OK because it has only one infra red receiver (remote receiver) to catch remote signals.
So TV remote seems bad as it works on channel buttons only.
Here is an easy test for remote, watch remote front through any digital camera or even cellular phone camera will work and press channel button on remote, you will see blinking LED at front of remote while watching it through camera. Now press other buttons of remote and I'm sure that LED wont blink.
Sep 07, 2009 | Mitsubishi Televison & Video
I have an shd-3010 with the remote and the channel button doesn't work nor do the buttons to change the station on the remote. Yet the power button works as does the volume buttons
Here is the solution. I have had this problem for 2 or 3 YEARS... (I finally gave up and just changed the channel manually).
The solution is exceedingly simple. You'll want to punch yourself (or at least, I did... :-P )
Press Menu. Press Menu. Press Menu (3 times total)
THEN, scroll down to "Channel Fix"
It will say either "3" or "4." What this does is it makes it so that your HDTV is always on channel 3 (or 4) when you turn on the device... AND it apparently disables the channel functions of the remote control, for some inexplicable reason.
All you have to do is change this setting from "3" or "4" to --> "OFF"
You will now have full channel and button control.
Enjoy! <(^_^<)(^'.'^)(>^_^)>
Jul 17, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
I have a old rca tv. today when I turned the tv on the stations just keep changing and its a static. What could make that happen?
there are a few possibilities. Only two of which you can correct.
First, blow some pressurized air into the remote control, especially around the channel up and down buttons.
Second, see if the channel changing stops when you remove the remote battery.
third, blow compressed air into the channel up and down buttons on the tv.
If you are still have the problem then you have an internal part to replace and we recommend you use our premium service for that.
Good luck.
CH
Jul 29, 2008 | Televison & Video
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
TV is ON....only ONE STATION. New Remote Batteries. Will Not CHG ch or VOLume
Unplug AC electrical cord for a bit then plug in and see if it resets.......................T.
Feb 12, 2008 | Televison & Video
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Toshiba 24AF45 24" TV Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
