Question about Linksys Wireless-G WRT54GS Router (e125894)
I can not connect to my router anymore, was working fine yesterday
  • persephone3 Nov 29, 2008
    Have tried resetting and plugging and unplugging. No dice.
  • Anonymous Dec 02, 2008
    can't hook up wireless router
    Genius:
  • 1,913 Answers
Access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Posted on Nov 15, 2008
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 01, 2012 | Computers & Internet
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
Why my wifi doesnt work anymore, it was working yesterday with dir 615
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Oct 04, 2010 | D-Link DIR-615 Wireless Router
I cannot get an internet connection through the router . It was working fine untill I had the cable co. fix my TV cable yesterday. Could this be related, or is my router broken?
It could be connections issue, connection from the Cable box to the Router, Disconnect the Router Cable, Turn off the Router and try to boot again.
This should help
Jun 26, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
I am on hughes satelite internet and my connection failed yesterday when the cord from the back of the modem came out. It is back up and running but only directly from the modem to the tower NOT thru the d...
You will need to check the settings of the router .
You said that when you connect the computer to the modem it works, now connect the modem and computer to the router and open the router set up page .
Check the settings of the router.
You may need to set up the router again.
Click Here for step by step info
Dec 06, 2009 | D-Link (DI-711) Router
Cannot connect anymore
Does the router work with the wired port connection? It's entirely possible that the router just went belly-up on you ...Linksys is an awesome brand, but sometimes it happens.
If the wired part works, the wireless transmitter inside may have gone bad. Best to just get a new one for about $50 ...but keep the old one in case you need a wired connection somewhere else around the house :)
Sep 28, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys Wireless-G WRT54GS Router (e125894) Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
