Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
Lexmark S305 IMPACT Prints incorrect colors - Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Try to perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
Posted on Aug 22, 2012
SOURCE:
SOURCE: How do I stow Lexmark Impact S305 Control Panel?
find a tight plastic locking clip on the underside of the control panel. It may be at the top middle edge on the underside. Give it a very firm upwards press and it should unlock the control panel section.
Posted on Nov 13, 2010
  • 544 Answers
SOURCE: I need ink refill instructions for Lexmark Impact
Only the Lexmark 100A and 100XLA are refillable.
Click
http://www.refillinstructions.com/Lexmark/L21.htm
for instructions.
Posted on Jan 20, 2011
  • 142 Answers
SOURCE: i to updated firmware as
if you can...please return your old firmware version and please don't listen to any official Tech support because they care only for taking your money:(
...P.S. Please by yourself a new LASER printer and stop using this kind of "INK SHITs)
pifonski
Posted on Feb 19, 2011
mcavinee
  • 236 Answers
SOURCE: Lexmark Impact S305 printer continues to jam paper
Clean the rollers with alchohol solutions
Posted on Mar 19, 2011
Printtech
  • 1087 Answers
SOURCE: how to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
Posted on May 24, 2011
It keep jamming up on the left side
check in tracks for paper pieces or dust or other small lint that can cause a one side imbalance on a lexmark
May 31, 2012 | Lexmarkr Impact S305 Multifunction Printer...
Error loading communication DLL on my Lexmark s305
Try to uninstall the Lexmark software. To do that, on your computer, press on Start > All Programs > Lexmark > S300 Series > Uninstall Lexmark S300 Series.
Then download an updated driver online. Just click on the link: Lexmark S305
May 31, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Colors not showing up
A firmware update for the Lexmark Impact S305 printer addresses print quality issues. Please visit the Lexmark website at http://bit.ly/guXLhl to download and install the update for your model. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the problem continue even after the update, please contact Lexmark Technical Support Center for further assistance.
Dec 13, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I have loaded all new colour and the black cartridges but error message says 'black ink is very low'
Please make sure that your printer is updated. You can download and install the firmware update for your Lexmark Impact S305 printer by visiting the Lexmark website at http://bit.ly/s305fw.
Should the error continue to display on your printer screen, please contact Lexmark Technical Support Center for additional assistance.
Oct 14, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My Impact s305 printer has full ink cartridges-I even just replaced one a few minutes ago and the color ink won't print out-only the black will. I've already tried to reset factory settings. It...
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Aug 10, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Hello, I allways get papperjam in my lexmark Impact S305 printer... How do I solve the problem?
Check Lexmark article on Paper Jam Troubleshooting on 2009 Printers. If you continue to experience paper jam issues on your printer, please contact Lexmark Technical Support Center for additional assistance.
Jun 22, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
How do I stow Lexmark Impact S305 Control Panel? The printer control panel is stuck in the up position.
Nov 08, 2010 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
228 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
