Question about Maytag PAV2300 Top Load Washer
Small brown spots on whites
When I wash my white clothes, they come out of the washing machine with small brown spots on them that I can't get out. Why is this happening?
  • kathoderaybl Dec 22, 2008
    what do you think, I just had the same problem. The spots are the size of the washer holes and are on the things that stuck to the sides of the drum.
  • Cleve McGehee Apr 29, 2013
    Did you ever get an answer to how to solve the problem of the brown spots the size of the washer holes?
    Sergeant:
  • 217 Answers
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Posted on Nov 29, 2008
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
How to stop brown **** marks from washing machine
too many cloth at once and need to clean the glass and seal alot
Aug 11, 2014 | Washing Machines
I just washed a load of white towels they came out spotted with brown and black spots with a line of black goo at the water line machine is less than 3 years
your using to much soap, the collection has come off the rim of your stainless tub. by using a white cloth an cleaner you can wipe it off clean. the gasket <rubber seal> is probabbly that way too. you can buy affresh tablets an clean your washer weekly, follow the directions on the package.
you should be using 2 tablespoons of detergent per load. 1 tablespoon on delicates.
Jun 03, 2011 | Washing Machines
I purchased the Kenmore Elite washer approximately five years ago. I have had no problems with it operating. However, since purchasing this washer I have ruined almost everything white I owned and avoid...
There has been many reports of complaints regarding this problem and it was found out that the gray spots on white clothing are caused by the fabric softener. The Kenmore Elite is a "highly efficient" machine that it uses very minimal amount water when washing and rinsing. The minimal use of water results in the fabric softener not being diluted completely and eventually makes gray spots on white clothing. The ridiculous solution to this problem, as Sears "advised" is not using fabric softener for white clothing. But you may also try putting the fabric softener in a small plastic bowl just enough to hold it and place it inside the machine prior to the final rinse. Using only the suggested amount of detergent and avoiding the use of detergent powder with speckles reduces the possibility spot occurrences in your while clothing.
Aug 27, 2010 | Kenmore Elite 45986 Front Load Washer
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
Oct 17, 2007 | Washing Machines
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
511 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
