Getting power from car battery there's no power to amp it does not go on
SOURCE: alpine mrd-m500
Hi SPDGOD, Could not find exact, but close manual. It is the MRP-M450 mono block amp from alpine. Go to this url and view in Adobe. Print it if you need to http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
SOURCE: ALPINE MRD-M300 MANUAL
Ask and ye shall receive....
http://vault.alpine-usa.com/products/documents/OM_MRD-M300.PDF
SOURCE: alpine mrd-m501 amp
the subs cant handle all the power you got it set on turn off all the settings and then turn off your car and remove your face plate and then it should be ok. it does that because the subs cant handle the settings you might just have them a lil high
SOURCE: Alpine MRD-M500 Amplifier
That is a code to inform you of an issue, and to help direct you to a particular area of concern
HOT & E-1 = both for heat issue
E-2 = for a voltage issue
E-3 = for a current issue.
While yours is a current issue, that reflects a problem with your input or output signal pairs. You should disconnect the subs at the amp, then operate the unit as normal to see if the code reappears. This is the start of your process of elimination, where as you will be able to determine the general location of the issue, weather it is before - internal - after the amp, hence If after the subs were disconnected, the code did not return then it would be obvious that you should focus on the subs and their signal pairs. troubleshooting in small increments until the issue is discovered.
Hope this helps...Good luck
Aduz
SOURCE: programing my alpine mrd-m1000
Hello steve1914,
You can download a PDF copy of the manual here. There's no cost for the download from Crutchfield.
Hope this helps.
Hi SPDGOD,
