Question about Toshiba e740 Pocket PC
Toshiba E740 Power Problem
Hi, My E740 works great except for the unit will not turn off. It shuts down the screen for a second, then beeps and comes back on. It turns off fine when connected to the docking station, synch cable and wall adapter. occasionally it will power down fine, but rarely. I upgraded to the latest firmware (1.0618.0409) and replaced the battery. Does anyone know what's wrong?
Hi, I noticed that the firmware that you have is not the latest, the last provided was 1.0623.049 which was released a few years ago. I would install this, in addition to the other patches from the Toshiba web site. Hopefully this will overwrite any software quirks for you. regards, Keith
Posted on Jan 24, 2007
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Why is my Canon Pixma 830 Printer beeping once upon start up, the screen lights for a second then the printer shuts off?
Either a power supply fault or there is a fault in the main circuit board. You may find a replacement power unit (they are held in by two clips ) at an electronics recycler or auction site like e-bay, but the main board is not an available part.
Dec 10, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Blank screen, triple beeps when trying to shut off
I have looked around for you and here's what i found:
Try holding down the power button on the front of the unit till you hear a beep (4-5 seconds). If you don't the unit will power on, but won't reset the video settings. Most people don't hold the button down long enough.
i hope i have helped and i hope it works,let me know how goes !!
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Toshiba Touch Screen does not work
Hi This may help you :: Select , Settings, System tab, Align Screen to adjust the touch screen. If the screen alignment loses calibration it may not be possible to adjust alignment using the above method. Also, here is a link that may help :: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuals-userguides-su530093-ppce400ug20030916pdf&sliceId=pdfPage_113&dialogID=6730022&stateId=1%200%206728267
Apr 30, 2007 | Toshiba e740 Pocket PC
BT Problem Battery/Power Problem
In my opinion it is always very risky to buy some second hand unit because you can not be sure if every hardware component works properly. The best solution for you is to contact service partner and let them check the PDA. It is also possible that power supply electronic has some malfunction
Sep 08, 2005 | Toshiba e740 Pocket PC
Power fault
In y opinion there must be some problem with battery power supply. In my opinion you should contact service partner. I hope that your unit has still valid warranty.
My PC not turn on
The Toshiba Pocket PC e740 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower right edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-4 (21 of 182).
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
185 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
