Trying to install Router SNB5600. What does Java Script Application message "The WAN IP can't cover the LAN side subnet" Mean please?
    Genius:
  • 1,913 Answers
Access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Posted on Nov 15, 2008
Static route for two different subnets
You did not say where are your two computers. Anyway, computers should work on most subnets routes except between 10.20.30.0 and 10.20.40.0 subnet.
Static routing should be set on two computers not on routers.
Assume computer A is connected to 10.20.30.252 Router A and Computer B is connected to router B.
On Computer A, you need to add route to -inet 10.20.40.0/24 via GW 203.187.106.147, and on computer B to set rotue to -inet 10.20.30/24via GW 203.187.106.138. That is all you need.
Apr 04, 2014 | D-Link Computers & Internet
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
"lan subnet conflicts with wan subnet". I
http://technet.microsoft.com/en-us/library/cc958832.aspx
This link above explains subsets, a subset is the like this... 255.255.255.0 in the address coding as explained in the above... You need to change this
Oct 11, 2011 | D-Link DIR-615 Wireless Router
How to configure my tcp/ip TP-link access point
The router has both a "WAN" (Wide Area Network) side
and a "LAN" (Local Area Network) side.
On the WAN side, most ISPs (Internet Service Providers) will provide the values for IP-address, subnet-mask, and gateway.
On the LAN side, you should just use the "default" values.
Connect your computer via an Ethernet-cable to the router,
and the router will supply values to your computer,
so that your computer can communicate with the router.
Nov 06, 2009 | Computers & Internet
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
I have a actiontec gt704wg trying to connect another router behind it .... iam not able to ...
your other router has to have the following settings:
1) it's IP must be on the same subnet as your actiontec. The subnet is the "third" number in the ip address. So if your actiontec has ip of 192.168.1.0, your other router must have IP of 192.168.1.XXX where xxx is some number other than 0.
2) the dhcp server of your other router must be turned off
3) you must run a lan cable from a lan port on the actiontec to a lan port on the other router. Note that the internet/wan ports are NOT used on either router for the purpose of daisy-chaining routers together.
Dec 07, 2008 | Actiontec GT704WG Wireless Router...
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Dec 21, 2007 | Computers & Internet
Netgear router
I'm not sure this is the issue but it is worthy of review. Routers are designed to separate networks or more properly subnets assuming you have the wan side of one router connected to the ISP and the wan side of the other router connected to the first router. You have two subnets in your house and they cannot be addressed the same. If the lan side of each router is addressed as 192.168.0.1 you have a duplicate IP address confusing situation that could well cause the devices to completely shutdown as you indicate. The first step of the resolution is fairly simple configure the LAN side of the second router to have 192.168.2.1 as its address. Assuming further that both subnets have masks of 255.255.255.0. The first router's subnet is 192.168.0 and the second router's subnet is 192.168.2 -- they are different and that is correct. The WAN side of the first router is configured correctly or it would not have worked with the satellite. The WAN side of the second router needs an address in the first routers subnet such as 192.168.0.2 if you wish to statically assign it. However this can successfully be defaulted to a dynamic IP address too. Configured in the stated manner the routers should work successfully. They can both have DHCP enabled for their own subnets. Computers hooked to the second subnet could still fail to access the internet if they lack suitable DNS addresses either provided by the router or statically configured in the wireless adapter configuration.
A second alternative would be to have a lan port on the second router attached to a lan port of the first router. now you have a single subnet and have effectively dumbed down the second router to being either a switch or a hub not bad. However there are issues here too. If you did not shutdown DHCP services on the second router you could have two routers competing to assign duplicate addresses to machines as they join the network which will make for unreliable and somewhat random failures of the networks to service attached machines -- so turn off DHCP on the second router. Should the second router have a static IP address on the wan side make sure it is unique and not in the first router's subnet. The lan side of the second router should be assigned a unique address in the first routers subnet although it will not really be used for anything.
If you have any questions please respond with a comment to this problem.
Dec 18, 2007 | NetGear WGT624 Wireless Router
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
