Question about Whirlpool GY396 Electric Kitchen Range
Whrilpool accubake duo MOD # RF388LXKQ error code E-2 F-3
Can some one tell me what these codes mean.
Vernon
    President:
  • Whirlpool Master
  • 2,651 Answers
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Nov 16, 2008
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
I have whirlpool accubake model wle 3430 almost 10 years old and have a code E1 F1 and oven is not working ! 1 e
The F1-E1 error code means the control board has detected a problem within the control itself and the control board needs to be replaced
When ordering the control please note it may also be called the,CLOCK,EOC or Electronic Oven Control in addation to the control board..any of those names it will be the same part.
GENE
Sep 04, 2011 | Whirlpool Accubake SF362LXTS Kitchen Range
I am getting E0 -F2- error on my Whirlpool Gold Accubake oven display. If I press cancel it sometimes will start but has been working less and less. The range is quite old and I do not have a manual. What...
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Mar 29, 2011 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool mod. WFG361LVS 0 SER RW3911592 code : F5E2 on baker
This probably a problem with the wiring of the door lock assembly. Here is a list of Whirlpool error codes.
Mar 20, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
My oven is showing an F1-E1 error code. What does this mean
F1 - E1 EEPROM checksum error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
Oct 25, 2010 | Whirlpool Accubake RF362LXTT Electric...
What does the error code F2 EO mean?
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
Sep 21, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Accubake is displaying a PF code...should I buy it?
It appears your clock assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 04, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool GY396 Electric Kitchen Range Logo
390 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
