Question about Gateway 450ROG Notebook
Gateway 450rog I decided I wanted to have a second hard drive -- seemed simple enough. I purchased the caddy and hard drive, read instructions on the internet. I understand that there are two ways of connecting the caddy - hot/cold. Well, being the risk taker I seem to be, I decided to not shut down my laptop. I closed the lid, removed the DVD player, inserted the caddy with the hard drive. Windows did not recognize it, so I thought I needed to learn more about setting it up in the BIOS (?) and would wait until I had more time. I closed (not sure it got closed all the way), swapped the caddy for the DVD player, opened the lid to a black screen. Did I fry something? it won't boot with AC or battery -- just a black screen. Dumb and bummed. Would appreciate your advice. Claudia 1thess5161718@verizon.net
  • 1 more comment
  • y2kharmony Nov 15, 2008
    the first answer only addresses the non-recognition of the second hard drive without a new boot. That is moot now because, if one reads the post above, I now have a black screen -- NO BOOT. Please tell me if I fried my motherboard if you know or if the problem is possibly something else. Thank you.
    Do I need to replace the motherboard? Is that possible for a dangerous knows something about computers user?
  • y2kharmony Nov 16, 2008
    vegakitten was very helpful in resolving my problem -- back to normal now. thank you Juanita!
    Sergeant:
    Champion:
  • 283 Answers
Detached the memory of your laptop.. then attached it again... Post for further information..PLease dont rate me if not satisfied with my suggestions....Thank you..
Posted on Nov 16, 2008
    Genius:
  • 1,011 Answers
Sir,
This is not problem with motherboard. u wont replace motherboard. When the laptop bootup press F8 they showing the list of harddrive(harddrive Number) that detected. If u show the second hard drive (i.e caddy) u need not to worry. Sometimes the OS wont recognize the external hard drive it is problem with OS itself so u just reinstall the OS it will be detected.
let me know if it helped or not
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Nov 16, 2008
    Step 5: Configure the new driveWhen you power up the
    notebook, the system BIOS should automatically recognize the new drive.
    If you created a bootable backup disc or a complete image disc, place
    it in the optical drive and follow the application’s instructions for
    restoring your data. You may have to update a driver or two, but you
    should otherwise be ready to go. If you are performing a clean Windows
    installation, use the original OS disc and have your CD key code handy.
    Follow the formatting and partitioning instructions, and load the
    operating system. Once the OS installation is complete, you can begin
    installing your applications and any necessary drivers. Then copy over
    any data you’ve stored on external drives or discs—and enjoy your
    companion’s new storage horizons right away.
  • 685 Answers
No its not dangerious if you get the new mother board and need help you can send me a message and i can walk you through it.i can even help you find a replacement motherboard.if you give me the model of your computer i'll be more then happy to get you some prices on a new motherboard.please let me know what you think.
  • Gateway Master
  • 6,487 Answers
Yes you now need to replace the motherboard and don't worry it should be easy and the new motherboard has a step by step guide that you can follow on how to install it ....
Posted on Nov 15, 2008
    Scholar:
  • 181 Answers
Its a common problem faced by many new users with lack of technical knowledge.as it is compulsary to shutdown the system before connecting any new card or device to the system.this is a very common and basic thing.should be always kept in mind.as u can remove the plug and battery and wait for few minutes.also try to charge the battery and then try.but if this does not help.
u have to call the service center if its still under warranty or go to the local hardware /software reparing person in your area as the motherboard needs to be checked sometimes adjusting the BIOS setting through computer get the machine start working.if the bios settings r proper then it could be minute short tracking on the board.its a 50-50 chance of getting it repaired.
feel free for further assistance.
thanks.
  • 90 Answers
Unplug the Harddisk and try booting the system and go in BIOS first.
Pressing DEL , ESC or other FN key you will get in bios there chose option for Boot priority and select the Hard disk.
Press F10 and exit. It will start your LAPTOP.
Connect the harddisk in OFF Mode and when it detect then You need to format the Hard Disk first, so that it can be readable and view in the list.
    Sergeant:
    Champion:
  • 200 Answers
Hi
first check whether jumper setting..
If its in master then it will detect change into slave and then connect..
then restart the system and check in bios configure..
thank you
  • Thafa Nov 15, 2008
    Hi
    Check the battery...
    connect with the ac and then check it if its fails means..Then the problem in motherboard..
    thank you
  • Thafa Nov 16, 2008
    Hi
    If u have warranty then claim it..
    Warranty is out of date means u want to buy new one...
    Thank you
  • Gateway Master
  • 13,433 Answers
Have you tried to unplug the AC and the battery? then plug in only the AC, does it boot up?
if not, you probably have a broken motherboard, You can try your warranty but its unlikely that they would repair it for free.
  • 599 Answers
Yes.. sorry claudia ... you should have shut the system down first, you cooked it
  • 101 Answers
When you are installing a internal hard drive you always need to turn the system off first, the bios will detect the drive on startup.
How do I move files off a hard drive to a host computer with a caddy?
Unless they are password protected you should be able to copy and paste or drag them across if you open up 2 windows1 for where you want to put them on the host and 1 for the caddy.
Nov 23, 2014 | Gateway Computers & Internet
I need a hard drive for a older gateway 450rog that goes in the front
Google the Type HDD and the size you want. Ebay is one option.
Jan 08, 2013 | Gateway 450ROG Notebook
HARD DRIVE
You need to remove the hard drive from the laptop to determine if it is an IDE/PATA or a SATA hard drive. Then you can purchase the correct type for your model laptop.
Jul 15, 2012 | Gateway 450ROG Notebook
Hard drive password
If you can't remember the password,i'm sorry to say that you should replace the hdd with the proof of purchase.Fee may be charged.
May 03, 2009 | Gateway 450ROG Notebook
Confused on how to install gateway hardrive
Instructions on how to replace the hard drive:
http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353faq85.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Gateway 450ROG Notebook
Gateway 450ROG only recognizing 7805 MB of 60GB hard drive
you may have to wipe that harddrive clean and start over new
Dec 12, 2008 | Gateway 450ROG Notebook
Replace motherboard
you need to look for a disassebly manual or instuctions for that model, these type of manuals are hard to come by so i'm affraid it could be trial and error, make a note of what your doing, assemble the screws in order of how you removed them, draw a simple diagram of the laptop layout as you take it appart so you know where the screws came from, there are also delicate ribbon cables underneath the keyboard, so take care to be gentle and be patient, you will get there if your competent enough as you describe
Nov 15, 2008 | Gateway 450ROG Notebook
What hard drive can I upgrade my old 450ROG with?
Sure you can. You can get your hdd on ebay at very reasonable prices and new.
Here you have one of 80GB new at $ 60 free shipping
http://cgi.ebay.com/New-Hitachi-Laptop-Notebook-80GB-2-5-Hard-Drive-IDE_W0QQitemZ320309086044QQcmdZViewItem?hash=item320309086044&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1308&_trksid=p3286.c0.m14
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Gateway 450ROG Notebook
Gateway 450ROG
Without a visual inspection it would be impossible to say. But it does sound like you will almost certainly need a new motherboard.
Feb 29, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
