Question about Frigidaire GLEB27S7A Electric Single Oven
I want to stop the self cleaning function
I tried pressing the "clear all" button but it didn't help
  • 421 Answers
To Stop or Interrupt a Self-Cleaning Cycle
If it becomes necessary to stop or interrupt a self-cleaning cycle due to excessive smoke or fire:
1. Push CANCEL.
2. Once the oven has cooled down and the word "LOCKED" shown in the display has gone out, then the oven door can be opened.
Posted on Nov 15, 2008
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    Oven self-clean won't turn off!!
    You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
    Nov 14, 2009 | GE Ovens
    What does the error code F1 indicate, on a Wolf Oven?
    I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
    Mar 24, 2009 | Ovens
    GE: E Profile Single Electric Oven Model: JSP40W0WJWW
    First press and hold the cancel/off button for 10 seconds.
    If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
    The 2 thermal switches are located on top of the oven behind the control panel.
    Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
    I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
    Aug 07, 2008 | Ovens
    Frigidaire GLEB27S7A Electric Single Oven Logo
    185 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
