Question about A-Top XBlade Mid-Tower Case
Power supply lighting up but when I push the ''On'' button there is
I have a XBlade 550 ATX 450 Watt Power Supply along with a Asus K8V SE MB. When I try to power up the PC I get nothing, I removed the panel and checked the lights to my Power Supply and they light up as does the green light on the Mother Board. Why am I not getting it to power up?
Thanks
  • damononeill Nov 16, 2008
    I tried a new power supply and it does the same, there is nothing. No drives start and no fans either.
    Novelist:
    Scholar:
  • 180 Answers
You may have a bad power switch on the front panel.
Posted on Oct 05, 2014
    Novelist:
    Scholar:
  • 85 Answers
Most if not all pc power supply’s have a short circuit protection feature that will not allow themselves to turn on if there is any type of short in the system
Example being : one day on my pc here one of the extra power plugs for the cd rom drives (the ones that are there for adding more drives with red,2blk,and ylw wires) was hanging down in the back of the case out of view and some how managed to make a perfect connection with one of the positive wires and a little notch on the metal case resulting in pc not turning on.
Also i have seen some rare times where a screw that was lose in the case had fallen between the motherboard and the metal panel that the board is mounted to causing a short which prevented the computer from turning on.
If you have gonna as far as changing power supply’s then you might as well remove the whole board and then putting it back in but only connecting the power supply first to see if it turns on with just the board and the power button connected and if it does then install each component one at a time testing it in between until it stops working again to be able to tell which device it is.
if it does not turn on with just the power supply and the board by it self then check the capacitors on the board usually the ones closest t o the CPU to see if any of the tops of them look like they are popped up (they should be perfectly flat on top and the lines perfect and if one of them are even the slightest bit rounded on top like they swelled up a little then the board is history...Hopefully this is not the case and to make this easier for you here is a pic I uploaded to my website for you so you can see the difference http://systemonenetworking.com/caps.jpg
Posted on Nov 25, 2008
What power wattage is good for this MB P5N32-SLI SE Delux Motherboard Which power supply
depends on what else you have got plugged in, I would get a minimun of a 400 watt from a good manufacturer, so you will have a good supply of power over the main rails, most cheap 400 watt supply's cant sustain any where near 400 watts
have a google for power supply reviews
Jul 17, 2010 | ASUS P5N32-SLI Deluxe Motherboard
Will this video card run my motherboard
Yes it will.
Here are the requirements needed to run it
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode).
  • Your board has the Pci-ex16 slot and the Corsair has the power to run it.
    Jan 20, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
    HP Mod a500n PC, flashing green ps light
    Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
    May 20, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
    Antec neo HE550 with Asus P5W-DH. PC does not start anymore...
    you do not have bad powersupplie.the problem is most likely video related or just as simple as,taking out the batterie and removing the power cord for a few seconds.count to 15 slowly.this will reset your computers bios.you may need to reset some of your settings.if you need more help just contact me.
    357reaper@live.com .i usually check emails every 1-2 days.
    If this dosnt work your video card may be bad.depending on what you would need i might have one.
    Mar 02, 2009 | Antec Neo HE 550-Watt ATX CPU Power Supply
    Backup server won't boot up
    Is it USB or SATA drive? In the BIOS there is an option to allow USB boot device.
    Jan 15, 2009 | ASUS K8V SE Deluxe Barebone Kit / ATX...
    Nforce4 a939 power led comes on, but nothing else
    I am on an nforce asus an32-sli premium, with a 939 in it right now you need a 450 -500V power supply. they are resourse hogs, also are you running anything into the cable or ribbon that the main drive is on, if so try running just the drive and nothing else plugged into the MB as a master 0. Don't forget to connect the sata if you are running sata. let me know if it boots in that config, also clear the cmos and pop the battery prior to booting.
    Dec 21, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
    Need to replace power supply on emachine 3502
    An ATX power supply should work. 450 watt should be fine unless you are running high end graphic cards.
    Dec 21, 2008 | E-Machines Computers & Internet
    Asus K8V SE Deluxe - will not turn on
    it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
    Dec 05, 2008 | ASUS K8V-MX Motherboard
    How do I replace atx power supply?
    yo dawg just do like buy a new connector and stuff you know what i mean dawg
    Apr 30, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
    New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
    The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
    May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
    Open Questions:
    USA@#1-877-778-89-69@#Avira Customer Support Telephone Number? Call USA1-877-778-89-69 Avira tech support is offer the power of any time, anyplace with the assistance of Avira Antivirus support phone number . Any body will easy accessibility the Avira Antivirus Support Phone Number. Avira Antivirus Support number provides technical help and support services in respect to the software system .Our expert Solved all type of issues i.e Netwok conflicts,Firewall configuration and window issues etc. For more detail call:1-877-778-89-69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.
    May 24, 2017 | Avira Computers & Internet
    See all A-Top XBlade Mid-Tower Case Questions
    A-Top XBlade Mid-Tower Case Logo
    331 people viewed this question
    Top A-Top Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
    Are you an A-Top Computer and Internet Expert? Answer questions, earn points and help others
