Question about Frigidaire FRS26R4A Side by Side Refrigerator
Tubing leaking in refrigerator door
The 'water in door tubing' in our FRS-22ZRFD side by side appears to be leaking. Is this tube replaceable? I have had the water/ice dispenser out for other repairs and also I have removed the plastic liner panel exposing the foam door insulation. Exactly how is the tube replaced since there seems to be no access.
Thanks in Advance
Dan
    President:
  • Frigidaire Master
  • 2,651 Answers
If your talking about the water line fron the bottom ofthe door to the dispensor head, it pulls out and is replaceable, might be a little tricke to feed through the door but ther is a channel in which it will push back through
Posted on Nov 20, 2008
Water dispenser leaks out bottom of door when I dispense water.
Sounds like a small hole in the plastic water tube inside the door. It is a replaceable part but you may need to remove the freezer door to do that. The old tube should come out the bottom near the hinge area. The new tube is then pushed up inside the same hole. There is usually a plastic conduit in the door for the plastic tube to follow. Here is the part number I found for the new plastic tube.
W10277960 about $42 to $45 depending on part store.
Apr 30, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Water leaks from bottom of freezer door
You need to remove the door from the refrigerator, then remove from the door the plastic frame carefuly, its snaping, and attach the new (1/4") line to the end of existing line then pull up the existing line softhly until the new one appears, check before all this if the line is broken at then of door or in the middle and if leak is below the refrigerator check from the solenoid to the door.
Jun 13, 2014 | Hotpoint HSS25GFP Side by Side...
Front door of side by side is leaking water
Hello there and welcome to fixya
ok on these units there is a plastic clear water tube that is connected to a push /pull type connection under the door that will need to be checked out to see if it is leaking
Furthermore Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment.
Dec 14, 2011 | Frigidaire FRS23R4A Side by Side...
I have GE side-by-side refrigerator, model GE GSS25LGM BWW. The tube from bottom of freezer door to water dispenser is leaking. It probably got damaged during our move when we removed and door and sat it...
I am sorry no repair I know of. As a repair tech we have to change doors often due to the same waterline freezing. there is no way in without damage to door . however you can buy the door from GE for about 300-400 dollars or do without ice & water thru door. Sorry I hope this helps
Aug 18, 2011 | GE GSS25LGM Side by Side Refrigerator
Hi, I just found a leak in the back of the fridge from the green water line. Is it something I can fix easily or should I have an expert take a look?
If water appears to be leaking from the back of the refrigerator, check that the water line from the household water supply to the refrigerator is not damaged or cracked. Check all connections that are accessible such as the connection at the supply valve and the connection point of the supply tubing onto the back of the refrigerator. Check that the tubing is firmly inserted into all fittings and all fittings are tightened.
Saddle Valve Shutoff Valve
Leaking from under the door
On exterior dispenser models, if water appears to be leaking from under the refrigerator door, look and feel under the door to ensure the water connection to the dispenser is properly done. Firmly push the water tubes into the fitting.
NOTE: This connection was disconnected if the doors were removed during installation or if the door swing was reversed.
Leaking at the filter
Ensure that the filter is correctly installed.
Jul 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
GE refrigerator Leaks in back when trying to use water dispenser
That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
