Question about Nikon Cameras
I have some infrared film: IR 820c. How do I take photos with this film in my Nikon N80?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
From the N80 manual: "Infrared films cannot be used since an infrared sensor is used for the detection of the film frame position."
If you need a manual, you can get one at http://butkus.org/chinon/nikon.htm
Posted on Dec 30, 2009
I've used the Quantaray PZ-1 DSZ on my Nikon N80 film camera and had no problems. I would like to use it on my digital Nikon D60.
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D60 just as you use it with the N80.
Jan 05, 2013 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Can't load the camera, it is a nikonF80
The F80 was called the N80 in North America. You can download the N80 manual from
http://butkus.org/chinon/nikon/nikon_n80/nikon_n80.htm
You'll find illustrated instruction for loading film beginning on page 20.
Dec 16, 2010 | Nikon F80 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Don't know how to rewind film
Hi there.
The film should auto rewind when it reaches the last picture and its been taken.
Take a look in the camera's menu.
Good luck and thanks for using FixYa!!
Nikon D40 SLR 6MP 18-55 Lens
I son't know how to turn a camera into an IR camera but I did find a website that shows you how to make a filter that allows you to take IR photos. You can make the filter yourself for free unless you don't have the items needed but then again the item needed are only a couple of dollars. Here is the link.
http://www.diyphotography.net/take_infrared_pictures_with_digital_camera_ir_filter
Nov 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Film speed override?
Press and hold the ISO button on the top left and rotate the command dial on the right until the film speed appears on the display. Release the ISO button and the speed is set.
In case your instructor hasn't told you, IR light is just below visible light on the spectrum and has a longer wavelength. Therefore, IR light will focus behind the film plane for a given setting. I.e., if you preset the lens to focus at 10 feet, the IR light will focus at a shorter distance. Unless your lens has a distance mark for IR, I would limit my shooting to longer distances and smaller f-stops to use the depth-of -field to compensate. When you are in focus for IR, the image in your viewfinder will be out of focus. The closer you are to the subject, the more out of focus the image will appear at the correct focus setting.
Sep 07, 2008 | Nikon N6006 35mm SLR Camera
Cameras Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
