Question about Fusion FEW12PK Car Subwoofer
Rca where in the head ubit do you fit the rca cable
On the back of your head unit you should have RCA inputs which are Red and White. most new stereos come with them standard. if you dont have em then you might have to take it to an car audio store and they might have to rig the line diff.
Posted on May 20, 2009
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
What connector do I need to connect my VCR to the Video Creator hardware?
Either a 3 headed RCA cable (the one with the yellow , red and white heads) or a S-Video cable and an 2 headed RCA cable for the audio (red and white).
Which one depends on what type of output the VCR has.
May 14, 2011 | Pinnacle Dazzle Digital Video Creator...
Where do these wires go
Hello sxy_spud,
Those wires are for the "speaker level" inputs to the amp. If you are using RCA cables from your head unit, you do not connect these at all.
If you are NOT using RCA cables from your head unit, the "pigtail" ends of the high-level input wires are usually connected to the rear speakers.
Hope this helps.
Sep 24, 2009 | Car Audio & Video
Car amp turns off when RCA wires are plugged in.
Hello joshua_m_moe,
A short or ground on the RCA cables or too high of an output level from the head unit could cause this. First, try it with the amp gain turned all the way down. Then, replace the cables with a known good pair. If the problem is still there, it's probably coming from the head unit. If there is another pair of preamp outputs, switch to them. If the problem still persists, I'd suspect the head unit.
Hope this helps.
Sep 18, 2009 | Power Acoustik TS1440-2 Car Audio...
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
JL 300/4 problem
If both the left front and left rear channels are out, reverse the RCA cables to determine if the problem is signal related. If the left side plays when you reverse the RCA cables, reverse them at the head unit to see if the audio changes sides. If it does, the head unit is likely the problem. If it doesn't switch sides when you switch at the head unit, the RCA cables are the problem.
May 22, 2008 | Jl Audio 300/4 Car Audio Amplifier
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Protection light turn on with sound
It's likely that the amp is defective but you should check the shield ground of the RCA signal cables before sending the amp off for repair.
Disconnect the RCA cables from the amp.
With your multimeter set to ohms, measure the resistance from the outer shield of the RCA cable to chassis ground. If it's more than a few ohms, that could be causing your problem.
If this is higher than a few ohms, short the meter's leads together to make sure the meter will go down to 0 ohms.
To check the shield ground of the head unit (assuming that the head unit is driving the amp directly), disconnect the RCA cables from the head unit and measure the resistance from the RCA output shield to the case of the head unit. It should essentially read 0 ohms.
Oct 21, 2007 | Cerwin Vega XL 600.1 Car Audio Amplifier
Fusion FEW12PK Car Subwoofer Logo
95 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
