Question about Samsung RS2556 Side by Side Refrigerator
Unable to removed samsung aqua-pure water filter
It appears to be stuck. Cannot moved 1/4 to left.
  • 1 more comment
  • saevans4 Nov 17, 2008
    Wrong refrigerator number. Should have been RS2533.
  • saevans4 Nov 20, 2008
    Thanks. The wrong number was given. Should have been SR2533. Looked for a release button but could find none.I still cannot get the filter out.
  • Vicky Vande Jan 14, 2009
    I have the same problem. I have a RS275 samsung side by side and the filter wont come off. they told me at BEstbuy where I bought it that it should come right off if u pull on it. But I dont want to break the Damn thing then i wont have water etc. It is simply stuck I think they do that on purpose so that u have to call in a service man from samsung or whereever .THATS problay how they make thier money on the service!!.
    anyway if anyone can tell us how to release the filter we would love u !!
    ANy swervice men/women out there???? HELPPPPPP!
    I'm a samsung owner of many electronics and thinking of switching over to LG!
    Scholar:
  • 58 Answers
A lot of different brand refrigerators have similar problems to this. I encountered this stuck filter problem on our Samsung side-by-side fridge that has the filter inside the fridge side and above the top shelf towards the back-right corner. Here is the solution that worked for me...
1. Remove the top glass shelf to give yourself extra working room.
2. Put on some rubber cleaning gloves to be able to get a tight grip.
3. Turn the old filter 1/4-turn to the left... it may take quite a bit of force.
4. Pull-down on the old filter to remove it. If it still will not come out, proceed to the next step.
5. After you turn the old filter 1/4-turn to the left and it stops, then get a good grip, because you will need to turn it an additional 1/8-inch to 1/4-inch. The left-edge of one of the vertical molding lines that run down the Aqua Pure filters should be directly under the centering-mark on your water filter holder.
That extra 1/4-inch counter-clockwise turn always seems to do the trick, and then the filter pulls down and out easily. Good luck!
Robert
Posted on Mar 03, 2009
    New Friend:
Had this problem. Read all the responses online, it was only by combining multiple responses that I could figure it out. I did this; turn the filter 1/4 turn counter clock wise, as directed; (this was exceedingly hard- I could only turn about a 1/16 " a day and my fingers were done for) When it reaches the 1/4 turn spot; take a rubber mat, used to open jars, place over plastic grab handle on filter and clamp down with a pair of long nosed pliers and pull hard. It popped out. !
Posted on Nov 09, 2014
  • Denise Cavanaugh
    Denise Cavanaugh Jul 25, 2017
    Thank you Ann, I tried all of the other suggestions repeatedly with no luck. I tried your muscle it method and tah-dah, it popped out with a few good tugs.
So I was having the same problem. I turned the water off to the fridge and then held the water dispenser down while I turned the filter and that did the trick. Had to do the same thing to install the new one and it worked!!
Posted on May 18, 2018
    New Friend:
  • 11 Answers
After trying many different suggestions including all the above. Simply use a automobile oil filter wrench on your stuck frig filter. It came out instantly with absolutely no effort. SIMPLE.
Posted on Jul 24, 2017
I had this problem. Finally I made extra sure (by looking at the new filter) which what it must turn and I put muscle to it until it came loose.
I twisted so hard I was sure it would break, but it came off without damage.
Posted on Feb 20, 2009
  • 833 Answers
Some of these units also have a release button on the front of the filter or on the receptacle frame.
Posted on Nov 15, 2008
I can not get the filter holder to twist off.. It seems to be stuck
Hello friend, thank you for your post!
I understand that your water filter holder is stuck and will not come off of your Frigidaire refrigerator. I see you have the Pure Source filter and after reviewing that it does not appear to have a filter holder. To remove that filter you should have to push it in and it should discharge. If it is not doing so, I would push it in and turn it slightly to remove it. If you are still having trouble with your filter removal could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the inside of your refrigerator normally on the right hand wall. I look forward to assisting you. -Matt
Aug 23, 2014 | Frigidaire Refrigerators
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Brand new Aqua Critter, won't move at all? Checked filter, checked hoses? Still will not move? Now what?
It looks like my cleaner. While it is hooked up to the filter, lift the unit, keep the suction side under water and flip it over. The feet should be moving. Feel for suction on the inlet on the underside.
There is a waterwheel inside the suction. Is it rotating? Is the suction hole clear, sometimes stones, acorns or other solid items get stuck in the suction that stop the water motor.
If there is something stuck inside or if the wheel is not moving, on my unit there are a few screws that can be removed to inspect inside. Naturally before doing this, disconnect the cleaner, drain it and take it to a location where it can be partially disassembled to inspect.
Gary
Jul 10, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
White calcium deposits in faucets
Sounds like scale build up in your hot water heater. Aqua-Pure makes a nice scale inhib thats installed on your cold water supply to your hot water heater. Parts and all is about $150.00. Add labor and your set unless you can solder then its a DIY. Homedepot sells the filtration device by Aqua-Pure.
May 16, 2011 | Rheem Water Heaters
Just bought a house that has a Aqua Pure Water Tx system. Model# 268-760. Not sure how to set it up.
The model number you provide doesn't come up n the Aqua Pure web site
Here's the link to the site :
http://www.aquapurefilters.com/
Jan 21, 2011 | Vacuums
I have an Aqua Pure model 268 /760 that is leaking from the base of the motor to the tank. Can this be fixed easily? I am unable to locate any manuals.
You will find a manual for the Autotrol Logix 268/760 here:
http://www.pentairwatertreatment.com/en-us/Products/Electronics/Logix+740_760.htm
Oct 01, 2010 | House Brand Aqua-Pure AP102T Whole House...
Samsung RS2556 Side by Side Refrigerator Logo
4,870 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
