Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Ice forming on freezer
I have Frigidaire side by side refridgerator/freezer and ice keeps forming on freezer floor. If I don't empty it every few days it will melt on to floor.
It appears to be coming from the back of freezer because there is a trail of ice running down back wall.
  • Anonymous Mar 23, 2014
    freezer is warm and ice on back wall
    Scholar:
  • 66 Answers
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Posted on Nov 15, 2008
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
Frost (ice)forms on back of freezer and the refridgerator area does not get cold. If I turn off for a few hours it works for a couple of days Thanks
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Aug 16, 2006 | Frigidaire FRS26KF5C Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
1,450 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
