Cd drive isn't working
The drive has gone from working occassionally to not at all. when i look at the properties for it, it is looking like the disk is full , but i don't understand how that can be. it is not a storage disk but the lite-on dvdrw shw-160h6s. i discs that need to be installed and it simply won't read them.
  • marice248 Nov 18, 2008
    thanks for the help! new drive was the solution.
  • 34 Answers
I just had this happen to me as well. Try opening the case and re-seating all the connectors on the DVD drive and the mother board. If the drive still will not operate after that you may have to purchase a new one. They are fairly cheap and easy to install.
Posted on Nov 16, 2008
All in one not burner
your need a program like NERO to burn disks, if you have got a program & the drive isn't picking up the disk in "my computer" then you need a new drive, because the heads have gone.
Mar 24, 2012 | Acer Computers & Internet
My cddvdw ts-l632h isn't working on my compaq presario c700 notebook it says it cannot load driver may be corrupted or missing problem no 39
Click start control panel administrative tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? ! or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 18, 2011 | Computers & Internet
Mother board cd is gone
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 05, 2011 | MSI K9MM-V Motherboard
My compaq presario cq40 again n again tell(there is no disk in the drive. please insert a disk in to drive) n i not have a cd rom driver plz tell me how is soul
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 15, 2011 | Compaq (120192-B21) CD-ROM Drive
Using nero 7 ultra enhanced,burn process finishes and says successful, but disk is empty. everything looks as if it is recording with nero vision, pc says disk is blank.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Aug 13, 2011 | Sony DRU-820A DVD RW Dual Layer Burner
I have a lg gh22ns50 internal drive.when i insert a cd it works perfectly but when i insert a dvd my dvd-ram drive turns into cd drive.opening it it says insert the disc.pls help
that seems odd if it reads cd's it should read dvd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps:
Jul 11, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My drive is HL-DT-ST DVDRAM GH20NS10. the dvd drive is working properly[reading & writing] with disks which are full or partially full.but it is not reading or writing a BLANK DVD. What should i...
is it a cd/dvd rw
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 22, 2011 | Computers & Internet
The files on my sandisk seem to have disappeared, but when you look at the properties, it shows there is disk space used. Also, when I access previous files on disk, they open but in explorer the files...
u might be infected by a virus.
try running ubuntu live cd.
Download it from below link.
www.ubuntu.com/download/ubuntu/download
Burn ubuntu to a cd.
Put the disk and reboot windows.
u might be asked to pree key to boot from cd.
press any key.
when ubuntu starts plug in ur memory card and check if the files exist.
This should work 100%.
If u find the solution useful please rate me thumbs up..
Jun 10, 2011 | SanDisk 4GB microSDHC Memory Card
I cannot copy files greater thn 4 GB into my new transcend 500GB hard, it shows error, tht not enough disk space in the external disk drive, even whn more than 300GB is free in the hard disk..
Hi 711jay
Open the Computer folder ( My computer ) , right - click on the drive , select properties and quota . Look if the quota management isn't activated .
Best regards ,
fanaudi .
May 25, 2011 | Office Equipment & Supplies
No blank cd in drive, please insert blank disk, THERE IS A DISK!
Buy a new CD drive
-When the reading laser goes out on a CD drive, this is the error it gives. The motor to open and close still works, the computer just isn't able to read the CD.
Jul 11, 2009 | HP Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
