Question about Asko 24 in. D3112 Free-Standing Dishwasher
ASKO Overfill protection tripped
Hi, we have an Asko D3120 dishwasher that had a blocked pipe and the overfill protection was tripped. I've cleared the pipe and the water immediately pumped out of it. Now when I plug it back in the pump is still running and can't be stopped. Pushing the power button on the machine has no impact nor do any of the other buttons. The only way to stop it is to unplug it from the mains. I've run Asko and they tell me it requires a service techinician at a cost of $95 per 15 minutes plus parts. Since I know the problem was a blocked pipe and now it's not blocked I'm hesitant to pay a technician to come and 'reset' the machine. Does anyone know how I can reset it myself or what needs to happen for it to register that the problem is now resolved?
  • 4 more comments
  • Cristy Gill Nov 25, 2006
    this solution worked perfectly. Thank you.
  • Anonymous May 12, 2008
    I had Cristy's problem, but on a of the Viking DFUD042, which is made by ASKO. I removed the kickpanel, and the front plate, dried it out, but after I dried the base, I restarted a wash cycle. I heard water running briefly (for about 30 seconds - 1 minute), then the pump started running again. I assume, but haven't checked, that the base flooded again. I think I should remove the back panel to observe the leak, but I'm having a problem removing the back panel There are four screws, but the panel doesn't come loose when they're removed. Do I need to disconnect something else? There's no float switch that I can see. Also, what are the most likely causes of a leak?
  • Anonymous Dec 18, 2008
    exactly the same issue
  • Anonymous Mar 06, 2009
    Worked perfect! Thanks guys!
  • amwssw Apr 21, 2009
    tripped overfill protection from blockage in the sink/garbage disposal. Don't want to pay a tech had that last year with the filters! Help, please!
  • Ron Baker Mar 03, 2012
    Where do you get the Star shaped tool, required to open the front steel panel to access the excess water? I've tried allen keys and screwdrivers but they just don't fit correctly.
    Thankyou
  • 175 Answers
Ok, heres what you have to do. Remove the lower toe kick and then remove the panel behind that to gain entry to the lower portion of the dishwasher wher the guts are. You will also have to pull out the little brackets that hold the toe kick and all the screws will be t-15 or t-20 torx (little star shaped bits) Once you have all the panels out of the way, you will find water in the bottom of the tray there tripping the overflow switch. Remove the water with a wet vac or towel or something and the drain pump will stop running. If you can't or don't want to do all this, then just let the dishwasher sit for a few days or so and eventually the water will just evaporate and everything will work normally. Hope This Helps!
Posted on Nov 24, 2006
  • Douglas Henry
    Douglas Henry Feb 09, 2013
    Most likely casue of a leak is the very short hose that runs between the pup and the diverter valve. It is only about 3 iunches long with 2 hose clamps that need to be cut off as they are not resusable. the back panel often doesn't come off becasue the black tar-like insulation sags down over time and kind of glues the back panel in place. you can either cut the stuff away form the top of the panel, or try to pry the panel oout form the top, being careful not to dent the tub.
I didn't have the proper screw driver to remove the back of the machine (we have a d3121), so 1). i soaked up as much of the water as i could from inside the washer, 2). i lay towels around the machine, 3). then i tipped it (not all the way - i dont think that would be good for the machine), and kept it at a slant until the water stopped flowing. once the water was all out, i replugged the dishwasher and presto. Good as new! saved myself $95+parts (rip off!!!).
Posted on Aug 08, 2007
  • ogenopen Nov 17, 2010
    Thank you very much. The thought of doing the dishwashing the "old" way scared me stiff..
    it works :)
    arie (netherlands)
  • Apan Qasem May 13, 2013
    Tilting forward worked for me. Thanks for saving me money
We have Asko D3120 and experienced the same problem, pump would not shut off no matter which buttons we pushed. I tipped the dishwasher (after disconnecting it), some water leaked out and after that it started working fine! Thanks for the tips!
Posted on Apr 27, 2008
Hi Guys
I had the same problem as all of you above, pump would not shut off on ASKO D3121 dishwasher. Loosened machine and tiped it forward (caution : water will be everywhere - be ready with shop vac)
Vacumed all the water inside to reset the switch and we are back to business - NO expensive service call!!!
Thanks All
Posted on Jul 08, 2008
I can vouch for the overfill protection solution. I have a Asko 1385, dried the overfill pan, and Whala!! worked just fine. Otherwise the pump just kept running and wouldn't shut off. Thanks for the tip!!!
Posted on Dec 28, 2006
  • 2 more comments
  • MacSolve Sep 06, 2011
    2011 and the solution still works! Re: wet vac - be prepared to fashion a tiny hose to your vaccum. Cut the hose at a steep angle so it can lay flat on the pan. I used a washing machine hook up hose, cut off what I needed and jamned a small funnel into it which I then held tight to my vaccum hose. Suction was strong enongh that it worked in seconds.
  • Carson Dec 08, 2012
    You would need to be sure the vacuum is designed to suck up fluids otherwise you will have a broken vacuum as well as a drowned dishwasher
  • Marc-Alexandre Barbe
    Marc-Alexandre Barbe Feb 08, 2013
    I actually used the pump of a Windex bottle that I was spraying on a towel to get the most out of it and used the towel to suck whatever was left. Now everything is back to normal. Good if you don\'t have a vacuum and that you have properly screwed the dishwasher in place! Cheers!!!
  • phil
    phil Jan 10, 2017
    thank you Marc Alexandre for the idea. I ended up using a soap dispenser head. ... might have tendinitis but got the machine going. loved your idea. thx
OK I just had the same issue with an Asko d 3120. Bought the house from a "contractor/developer" - read Flipper
taking the dishwasher out was an all day affair.
DISCONNECT POWER
I actually unscrewed the food screen thing, and felt the water in the bottom of the hole.
Get any thin tube and a pump. I actually used a dispensing pump from a fiberglass resin kit, but think push down ketchup pump at the ball park, or any smaller pump. (A large syringe might work as well.
Draw out as much water as you can (you have to angle the tube a little left) .
reconnect power, and works fine.
Not sure If I got all the water i needed out (will know tomorrow i bet) but sure beats removing and tipping the machine.
Anybody know how much water pools to activate this thing? I got like 8 ozs out.
Posted on Dec 29, 2008
  • Douglas Henry
    Douglas Henry May 23, 2015
    You can't get the water from the overflow protection out from inside the dishwasher. There is a separate tray BELOW the machine that catches any overfill, and that's what has to be removed. It could hold up to a gallon of water pretty easily. If yours started working after you drained it form inside the machine, it wasn't an overflow/leak problem.
Called for a repair man today after trying the above and waiting a week. The girl taking my call was very helpful, and instructed me to tilt the machine first to empty it, however, she strongly recommended the machine be tilted backwards - not forward!, in order to avoid water getting into the electonics at the lower front.
Unfortunately that didn't do the job - so I'm now waiting for the repair man-
Posted on Aug 11, 2008
I had the same problem with my Asko D3120. I fixed it by doing the following: 1) Unplug the power (only way to stop the pump) 2) Remove the filters from the bottom of the machine (from the inside) 3) Use a sponge to remove as much waste water as I could from the drain area at the bottom. 4) Return the filters. 5) Plug in the power My dishwasher returned to normal :-)
Posted on Jul 28, 2007
All good advice if you don't mind having a go yourself and saving an expensive call out.
If you delve into the insides though do remember to unplug the dishwasher at the wall as you get very close to the live bits.
Also to get the panel behind the kick plate off you might have to remove the door panel first. That's not hard but getting it back on can be tricky. Make sure the panel is pushed right up to the plastic top part (where the control buttons are) so that the top two fixings screw into the metal tab on the door panel not just the platic bit.
Posted on Jan 28, 2010
    You actually only need to pull at the right angle on the metal panel behind the kick plate. It might seems like you are gonna break it but it won't. That way it saves you to have to remove the door.
Thanks a lot, empty the pan and it work, thanks everyone!
Posted on Oct 02, 2010
    New Friend:
Thank you all of the above (and google for finding this) ! My ASCO D3120 drain pump started continually running tonight and I couldn\'t stop it (except pulling the power cord out). After reading the above and thinking it was the overflow float switch from your same symptoms, I removed the toe plate and extra panel with 6 "star" crews relatively easily as I have a million tool gadgets to get into difficult places. Then I made up a small syringe connected to a thin rubber tube so it could reach the water tray and sucked out about 1.5L of water from the bottom tray (25mls at a time through the syringe). When i couldn\'t suck out any more water from the bottom tray (it was still wet), i switched it back on and it goes fine. Hello from Tauranga NZ ! I love my ASCO dishwasher. ASKO Overfill protection tripped - 83b375b3-083e-4892-8f29-4327f5878cd2.jpg
Posted on Jun 17, 2014
2 Suggested Answers
Timon90
  • 126 Answers
SOURCE: ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Posted on Jan 24, 2008
What does F2 mean
Hello, Welcome to FixYa. To answer your question..."What does F2 mean ?", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part. F2 means the control has indicated a overfill. This is meaning the overfill switch is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen. It may in fact have been caused by a long drain or backed up drain. I'm presently on my iphone so I can't post the pertinent info to resolve the error directly, however if you copy and paste this link to your browser all the info will be there and it will apply to your model Asko as well. http://www.fixya.com/support/t7832382-f2_mean Either that or visit my profile page and you'll see other post relating to the Asko F2 error, its meaning and remedy. Hope this helps, let me know and good luck. Regards, Macmarkus :)
Jan 17, 2011 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3120 seems to have a blocked drain hose, what do I do?
http://www.servicematters.com/maytag_library/docs/16010622.pdf
http://frigidaireservicetips.com/pdfs/486_5.pdf
OK those two service manual links should help you troubleshoot and hopefully remedy your problem. All DW's are very similar and what is troubleshooting for one, is same for many.
May 15, 2010 | Asko 24 in. D3120 Dishwasher
Drain motor runs all the time. flashing "glass" light , (overfill switch tripped ) but drain system now clear. How to reset. I am 5 hours (return trip) by car to nearest city.
used a (new, clean) plumber's helper to force air through the drain system. The pumping action removed the water from the sensor and back in business.
Oct 31, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Overfill Protection tripped on ASKO D3112 dishwasher
Nov 06, 2007 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3112 Free-Standing Dishwasher Logo
14,218 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
