Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn air electric range 20+ yrs. old. Fan on continuously.
Turned off fan after using but it stay'ed on! Replaced switch, motor stay'ed on regardless of switch position. Took apart new switch, rocker moves copper contact correctly to make and break connection. What next? How to get at motor...replace?
  • 2 more comments
  • cfatzinger Nov 15, 2008
    tried the oil. Fan runs great but still won't shut off. All wires I can see in junction box in original condition and no visible chafing etc. Rocker switch just seems to have been, "Taken out of the loop".
    i am assuming that the rocker switch in the open position breaks the contact and the fan should be cut of current. in the closed position the electrical loop is complete and the current should flow to the motor. But if I remove the rocker and pull off one of the wires, the fan continues to run. That's probably why the new rocker switch didn't fix the problem.
    craig
    Tried the oil. Can see no fray'ed wires. Fan runs even if one wire is pulled from rocker switch.
    Wireing dia. in wireing unit. too charred but many interconnects. The fan hot was conn. to many other things and one was the oven selections. hmmmm. when oven is turned to, "Accl Clean" the fan rocker is over ridden and runs continuosly. oops. sorry. I must have turned it during the day's cooking and I've never used the accl. clean so that was news to me.
    thanks for your help today.
    sincerely, craig
  • 1,543 Answers
Was going to suggest checking that setting, but guess you found it already. Glad you were able to find the problem.
Posted on Nov 16, 2008
    President:
  • 1,952 Answers
Replace the capacitor
Posted on Nov 15, 2008
  • 958 Answers
If you have a diagram, you can trace where the power is coming from. it could have not run from the rocker switch.
does it has a Relay or a PC board?
if it does, then it could be a welded contact issue. take all power off and see if there is still continuity on the line side and load side of the relay .
you may need to un weld the contacts, clean it and you can probably use it again.
tnx 4 using fixya,
Drcool :)
    Sergeant:
    Champion:
  • 200 Answers
Hi
first check whether power is coming to motor..
if its ok means..then
Just rotate the motor and then turn on and see again ur motor is not running means check the capacitor...
thank you
  • Thafa Nov 15, 2008
    Hi
    Check once again connection are properly connected..
    And then check after turn off the power is coming to line..
    If its coming means trace the line...
    thank you
    Scholar:
  • 181 Answers
Off the unit completely and put some oil in the motor area and sides leave it for some time.then ON the unit and check out.is it working properly or not.also check out any wires getting loose somewhere or getting cut somewhere before making it ON again.
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Replacing fan switch jenn aire D156
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex TV..it says it is 4 numbers
Jan 01, 2014 | Jenn-Air Cooktops
Jenn air gas/elctric slide in range self cleaning does not work
iF THEY ALREADY REPLACED THE EXHAUST FAN , MAY WANT TO REPLACE THE HI LIMIT THERMOSTAT AT REAR OF OVEN... THE THERMOSTAT MAY RESET AFTER 20 MININUTES OF COOL DOWN..
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Ventilation system faiure
Sounds like the fan motor is overheating and shutting off . A long duty time  for a motor that has never been disassembles serviced and cleaned. If it is easy to do, Dissassemble and remove the motor.Most motors are available at electric motor supply outlets.Yes even tiny ones.  Replace same ,clean fan . Reassemble.
Dec 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Fan
I have had those pop up switches go bad shut down the breaker to the unit and pwr up if it is still on the switch will need to be replaced (as long as all the burners are cool)
Jan 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
