Question about Amana ABB1927DE Bottom Freezer Refrigerator
Not cold enough to freeze ice cream, frost on back wall
Refrigerator works fine...freezer is not cold enough. have vaccuumed underneath periodically, so dust build up shouldn't be a problem.Have adjusted dial but no difference is noted. Have frost on the back wall.
  • 2 more comments
  • sbatts Nov 19, 2008
    i have the same problem
  • Anonymous Dec 04, 2008
    my freezer is exactly the same problem.
  • donna2016 Jan 13, 2009
    bottom freezer not cold enough, frost on back wall, please notify with solution.
  • donna2016 Feb 02, 2009
    Frost on back wall, turned off for 6 - 8 hours turned back on worked for a few weeks and then the frost on the back wall, not making much ice and not as cold as it should be.
    President:
  • 1,462 Answers
Is it a frostfree type?
Posted on Nov 16, 2008
GE refrigerator / Freezer - Erratic freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | GE Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Bottom not cold enough
did you remove the back freezer panel ? if not need to
is there a large anmount of frost on the coil behind the panel?
if there is thaw the coil with a hair dryer
if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
May 17, 2008 | Kenmore 21.7 cu. ft. Top Mount...
Freezer doesn't keep ice cream frozen
not being able to keep ice cream is not good, before doing anything ck a few things. make sur e to pull out unit and vaccuum under and behind unit, if it cant breath it cant freeze. check in back by compressor, is the fan running to cool the fan??? if the compressor is on so should the fan be. next id look behind the freezer wall for excessive build up of frost( it might even be buildin up with ice throughthte back wall, inwhich case you have a defrost issue
Apr 02, 2008 | Refrigerators
Kenmore refrigidaire, bottom freezer
It depends somewhat on the quality of ice cream. Some brands freeze easier than others. One reason is cheaper brands have more sweetener/sugar in them.
I think if your freezer is freezing water into ice cubes, it should freeze ice cream of good quality.
Try putting the ice cream where the ice cube tray is and verify ;this.
Mar 31, 2008 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
247 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
