Question about Whirlpool Washing Machines
AWM 6101 washing machine flashing problem FH all the time???
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: fault code fh on awm8143/1
Two questions: Is there water in the tub? Or...is the tub empty? If there is water in the tub you need to check the following: 1. Verify that you do not have a siphon problem. This is caused by placing the drain hose too far into the drain standpipe and/or sealing the top of the standpipe. This will cause water to constantly empty as the tub tries to fill. You need to have an air gap for proper drainage. 2. Check your pressure switch and pressure switch hose. 3. Make sure the drain pump is operating correctly. 4. Check operation of flow meter. This is what actually detects the water flow coming into the machine and causes the error to flash if the proper conditions on are not set. It will detect the AMOUNT of water entering the tub and it detect the pressure switch trip that shuts off the supply when the tub is filled. If there is no water in the tub you need to check the following: 1. Check your fill valve screens. Turn off the water and remove the hoses from the back of the washer. The fill valve screens are inside the hose connections on the back of the washer. It only takes a small amount of debris to restrict water. You can clean them out using cotton swabs. 2. Make sure your fill hoses are not kinked or clogged. Check the easy possibilities, first. I suspect you may have either a siphoning problem, or clogged fill valve screens. If you check everything and still have problems, I would replace your fill valve before suspecting a defective pressure switch or flow meter. Let me know if this helps.
Posted on Aug 18, 2007
jsrock516
  • 5911 Answers
SOURCE: help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Posted on Aug 27, 2008
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model AWM 6101 door wont open after washing has finished
the door can take anything up to 2 and a half minutes to open anyway but if it takes any longer than this, or will simply not open at all then you will need to get a replacement door interlock switch
May 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 8125/3 fault code FH
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves
Or
detected 48liters of water passing through it, but has not detected the pressure switch
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
115 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
