Question about HP Hewlett Packard LaserJet 3000dn Printer
HP Officejet All-in-One Printer
I was printing my monthy bank statement. The paper gave out. I put more paper in the printer. It would never start printing again. I went to "Programs" on my Toishiba Windows Vista computer. I opened the printer. I took the number of times off the ques. It would still never start printing again.
I don't know what I have done.
Maybe you could tell me.
Thanks
Clarice
    Master:
  • 638 Answers
Remove all the wires connected to the printer from its back.also wait for 5 minutes.then delete any pending printouts in the printque of the printer in your pc.shut down the pc.connect the printer to the pc.ON the printer.then ON the pc and then try printing it should work.
thanks.
Posted on Nov 15, 2008
My printer say out of paper
Turn printer off and on.
Check to see if there is a print queue and then load the papers to end the printing.
Try also turning the printer off and unplugging it from power and restarting your PC.
Plug printer back and connect with the PC and then turn them on.
You can also check for paper jams in the paper paths and manually remove any stuck papers.
Run a print test by:
  • Press setup on the printer menu
  • press 1 and then press 4
  • Press start color/start black.
  • Your officejet now runs a print test.
Hope this helps.Thanks!
Please rate this answer.
Oct 23, 2011 | HP Officejet 4110 All-In-One InkJet...
I have an HP Officejet printer that has now decided after printing some pages that it is out of paper. I put paper in the tray and it still will not print as it keeps saying error "out of paper". What do...
take out the ink cartridges, paper and then unplug the power ... after about 20 seconds, replug the power and then reinsert the ink cartridges... it should work fine..
Otherwise... it is a hardware issue .. printer needs replacement
Oct 13, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 6210 all in one, carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My hp officejet j4580 all-in one is having problems feeding the paper. Paper feeds partially then jams.Repeated attempts resulted in same action.
Hello there
May 06, 2010 | HP OfficeJet J4580 All-In-One Laser...
My HP 8500 printer worked perfect for 6 months, but now grabs about 10 pages of paper every time it prints and is always jamming up.
Hi there
You should allways gave the paper a good shake before putting in the printer and the paper should keep in a worm place or it will do just that pull in lots at the same time.
All the best Pineworks
Mar 15, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Streaks in printing with my HP officejet L7680
It could be paper dust on the paper. Try putting some new paper in the printer to see if that fix it.
Aug 13, 2009 | HP Hewlett Packard Officejet Pro L7680...
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Hewlett Packard LaserJet 3000dn Printer Logo
69 people viewed this question
Ben Johnson
